Install torq boxes and frame connectors on rotissere? #1311312
09/27/12 06:55 AM
09/27/12 06:55 AM
Central Ohio
rtidd440 Offline OP
super street
rtidd440  Offline OP
super street
Central Ohio
Anyone done this and had a problem? I need to make some progress for my sanity and well being. I have the US Cartool connectors, car is a 69 Charger and it is on a Whirly Jig. Any input is appreciated.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311313
09/27/12 08:23 AM
09/27/12 08:23 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's how I did mine, only my car was clean underneath and then got blasted a second time before paint. I put in frame connectors at the same time. First I pressure washed the whole car to get rid of grease and oil. Then blasted it bare. It was quick, easy and everything bolted on the car perfect.
I blasted the bottom clean on a Sat afternoon. Sat night I welded in the boxes and frame connectors. Then Sun I reblasted the bottom a little and then did the outside body with plastic media.
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311314
09/27/12 08:43 AM
09/27/12 08:43 AM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
I'm not so sure that's the way to go. I have always believed that the body will flex differently when on the ground with suspension then with mounting it on the rotissere. Some believe, although I may not, that it should be on the gound with even the full weight of a motor and trans in there.
I've seen projects that have intalled jigs temp welded before they put it in the air.
Re: Install torq boxes and frame connectors on rotissere? [Re: DANA60] #1311315
09/27/12 10:15 AM
09/27/12 10:15 AM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I tacked mine (frame connectors) in while on the floor and after it was back on the rotissere I finished welding them in. I don't know all about the body flexing, but I don't like taking chances. I did't put in boxes, but I might do it later and if I do I'll probably set it back on the floor. Good Luck and have fun with it.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311316
09/27/12 10:42 AM
09/27/12 10:42 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
what goes in first, torque boxes or frame connectors ??
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311317
09/27/12 11:59 AM
09/27/12 11:59 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Race chassis' are built on surface plates to keep everything locked in to its proper location during the assembly process and the resutlant heat cycles of welding and fabrication. This ensures everything is exactly where it needs to be for maximum performance. If you are building your car for maximum performance, then there is merit to using a surface plate.
If you are building a cruiser, odds are you are not going to introduce enough deviation to the spatial locations to make a big impact on your set up when driving. A slight deviation here and there will most likely go unnoticed. Evena casual strip/bracket car would fall into this catagory. This is why certain components have adjustment built in to them. The factory assembly variations were allowed almost half an inch in some places. I'm betting you will do a better job than that putting things together, so you already are improving the platform.
Since your car is all apart currently, no need to put all the loads in it to maintain panel alignment. You will be resetting those gaps as you rebuild the car. If your car was together, painted nicely, and already a driver, then I'd suggest duplicating current suspension loads to keep everything playing nice together.
Give casual use status, the order of assembly is also unimportant.
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311318
09/27/12 04:56 PM
09/27/12 04:56 PM
Andrews,In. U.S.of A.
67_Satellite Offline
I did mine that way. Supported the center of the car first with it in the upright position. Didn't want to cut the frame for the boxes with it only supported on the bumper mounting points.
Re: Install torq boxes and frame connectors on rotissere? [Re: TC@HP2] #1311319
09/27/12 06:48 PM
09/27/12 06:48 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
And there is always the possibility the unnoticed deviations might be an improvement. Counting angels on the head of a pin.
Re: Install torq boxes and frame connectors on rotissere? [Re: Challenger 1] #1311320
09/28/12 07:16 AM
09/28/12 07:16 AM
Central Ohio
rtidd440 Offline OP
super street
rtidd440  Offline OP
super street
Central Ohio
I do plan on a cleanup before I start, at least local wire brushing etc. i just wondered if there was any flex to the bare body while on the rotissere. I might mount a laser bore sight to my magnetic dial indicator base and aim it at a fixed target while I spin the car to see if anything moves. Probably just over thinking things as usual.
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311321
09/28/12 08:05 AM
09/28/12 08:05 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
That would be interesting to know. Please post your findings.
Re: Install torq boxes and frame connectors on rotissere? [Re: mopfried] #1311322
09/28/12 08:51 AM
09/28/12 08:51 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
X2
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Install torq boxes and frame connectors on rotissere? [Re: Rug_Trucker] #1311323
09/28/12 01:36 PM
09/28/12 01:36 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
With as sloppy as these cars were assembled, 1/8" here and there, it's a moot point IMO.
If you want to take the 'sag' out of it, turn the car upside down on the rotisserie when you tack them in.
Re: Install torq boxes and frame connectors on rotissere? [Re: RobX4406] #1311324
09/28/12 02:00 PM
09/28/12 02:00 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I welded mine in with the car on the rotisserie and it was fine. The rest of the car was solid and the COMPLETELY bare so there was very little weight.
Re: Install torq boxes and frame connectors on rotissere? [Re: Rug_Trucker] #1311325
10/01/12 03:47 AM
10/01/12 03:47 AM
Central Ohio
rtidd440 Offline OP
super street
rtidd440  Offline OP
super street
Central Ohio
I will try the laser idea and post an update. Been fighting major depression lately, trying to get meds right. Been asleep for most of the last three days. Sucks
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311326
10/01/12 08:55 AM
10/01/12 08:55 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Take care of yourself. that stuff is no joke. a lot of people dismiss it as just "a case of the blues" but battling depression can make your brain think in ways that a "normal" person wouldn't ever find logical.
It can make you find permanent solutions to temporary problems.
Good luck!
on the rotisserie and frame connectors...those laser numbers would be cool to know when you get around to it!
**Photobucket sucks**
Re: Install torq boxes and frame connectors on rotissere? [Re: rtidd440] #1311327
10/01/12 09:07 AM
10/01/12 09:07 AM
Cincinnati, Ohio
Cincinnati, Ohio
Yes take care of yourself first. I hate to think one needs drugs to help with depression, but I'll be the first to admit I don't know nothing about it. Well I do a little, like 10 years ago I went to my regular doc and told him I didn't feel right. Had a first class race team with 6 guys working/helping me and we were a top 10 car and several years a top 5 car with a great sponsor.
But still felt down . He gave me some medecine to try but it didn't let me sleep right. I threw it away one day and didn't finish taking it. Doc said come back in and we will find another drug that will work for you I said no thanks.
I had a achy body and went to a chiropractor too after my reg doctor. That was the right move as he got me on the atkins diet and I lost 87 lbs. He never did make any adjustments to my body after the first one which hurt me. Haven't been to the chiropractor now in 10 years and have kept the weight and depression away now since. Exericise is what works for me, it releases something that makes me feel good. Good luck and go work on your car and forget about the drugs.
Re: Install torq boxes and frame connectors on rotissere? [Re: Challenger 1] #1311328
10/01/12 02:59 PM
10/01/12 02:59 PM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
Rob, when you decide to start...Call me, would love to come help get that stuff welded in...
