Install torq boxes and frame connectors on rotissere?
#1311312
09/27/12 06:55 AM
09/27/12 06:55 AM
Posts: 819 Central Ohio
rtidd440
super street
super street
Central Ohio
Anyone done this and had a problem? I need to make some progress for my sanity and well being. I have the US Cartool connectors, car is a 69 Charger and it is on a Whirly Jig. Any input is appreciated.
Rob
70 Swinger 340 4spd FC7 4 sale
69 Charger auto Q5
14 Challenger SRT8 Core 6spd black
Deposit on Hellcat
Re: Install torq boxes and frame connectors on rotissere?
[Re: DANA60]
#1311315
09/27/12 10:15 AM
09/27/12 10:15 AM
Posts: 1,290 New Kent, Va.
bobbyb
New Kent, Va.
I tacked mine (frame connectors) in while on the floor and after it was back on the rotissere I finished welding them in. I don't know all about the body flexing, but I don't like taking chances. I did't put in boxes, but I might do it later and if I do I'll probably set it back on the floor. Good Luck and have fun with it.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
[Re: rtidd440]
#1311317
09/27/12 11:59 AM
09/27/12 11:59 AM
Posts: 5,393 Pikes Peak Country
TC@HP2
Pikes Peak Country
Race chassis' are built on surface plates to keep everything locked in to its proper location during the assembly process and the resutlant heat cycles of welding and fabrication. This ensures everything is exactly where it needs to be for maximum performance. If you are building your car for maximum performance, then there is merit to using a surface plate.
If you are building a cruiser, odds are you are not going to introduce enough deviation to the spatial locations to make a big impact on your set up when driving. A slight deviation here and there will most likely go unnoticed. Evena casual strip/bracket car would fall into this catagory. This is why certain components have adjustment built in to them. The factory assembly variations were allowed almost half an inch in some places. I'm betting you will do a better job than that putting things together, so you already are improving the platform.
Since your car is all apart currently, no need to put all the loads in it to maintain panel alignment. You will be resetting those gaps as you rebuild the car. If your car was together, painted nicely, and already a driver, then I'd suggest duplicating current suspension loads to keep everything playing nice together.
Give casual use status, the order of assembly is also unimportant.
[Re: Rug_Trucker]
#1311325
10/01/12 03:47 AM
10/01/12 03:47 AM
rtidd440
super street
super street
Central Ohio
I will try the laser idea and post an update. Been fighting major depression lately, trying to get meds right. Been asleep for most of the last three days. Sucks
Rob
69 Charger auto Q5
Deposit on Hellcat
[Re: rtidd440]
#1311327
10/01/12 09:07 AM
10/01/12 09:07 AM
Challenger 1
Cincinnati, Ohio
Yes take care of yourself first. I hate to think one needs drugs to help with depression, but I'll be the first to admit I don't know nothing about it. Well I do a little, like 10 years ago I went to my regular doc and told him I didn't feel right. Had a first class race team with 6 guys working/helping me and we were a top 10 car and several years a top 5 car with a great sponsor. But still felt down . He gave me some medecine to try but it didn't let me sleep right. I threw it away one day and didn't finish taking it. Doc said come back in and we will find another drug that will work for you I said no thanks.
I had a achy body and went to a chiropractor too after my reg doctor. That was the right move as he got me on the atkins diet and I lost 87 lbs. He never did make any adjustments to my body after the first one which hurt me. Haven't been to the chiropractor now in 10 years and have kept the weight and depression away now since. Exericise is what works for me, it releases something that makes me feel good. Good luck and go work on your car and forget about the drugs.
