Page 2 of 5 1 2 3 4 5
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310704
09/26/12 06:50 PM
09/26/12 06:50 PM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
Scott, regardless of what it runs, HAVE FUN!!! You've got a cool ride and if it doesn't make the number you're looking for .... It will get there.
Randy
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310705
09/26/12 06:51 PM
09/26/12 06:51 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
475 at the tires, it should go 125ish
et, hooking up and working it like a PG, 11.20
60's night suffer a bit, but it still makes good hp and the tq should be strong with the turbo.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310706
09/26/12 08:00 PM
09/26/12 08:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
This thing had been dynoed and made like 470 at the rear tires, so doing the math not like is real accurate is making around 600+.
470 at the rear wheels is not 600+ HP otherwise I'd be over 600. I just don't see it in that build sorry. It's a very cool car and I hope it runs great. I just don't see 11's. Boost is boost S/C or turbo'd. The gear is going to hurt a bunch. and again I'm not sure how the converter is going to act w/ the boost and the lazy gear. It's like dropping the hammer at 5k in a pedal car w/ a highway gear, the rpms are going to sink way down, when that happens the boost will drop. I'd think it would run a ton better w/ a 3800 stall and 3.55's. I have a buddy that runs 8's at 160+ in a turbo SB. He runs a 4000 stall and 3.73 gears...and that thing has a 700+ lift cam.
But hey prove me and a few others wrong and go put up the numbers.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310707
09/26/12 08:33 PM
09/26/12 08:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Its gotta good converter in it, the RPMs are not going to drop below 5000 most likely. I think the turbo will love the gear ratio and it will run down in the 11s.
With the proper converter gears have little effect on performance on an NA car even.
68 Barracuda Formula S 340
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: JAKE68] #1310708
09/26/12 08:41 PM
09/26/12 08:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That was blowing right through the conv also... it
had alot more in it
EDIT
that was on the old conv
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310709
09/26/12 08:58 PM
09/26/12 08:58 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Mr. Yuck. Do you want mustard or catsup with that crow?
Still at Milan. 5th pass, Zero boost launch, 11.30 @ 122 so far on only 8psi. Time to turn up the launch and the boost.
More later.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310710
09/26/12 09:01 PM
09/26/12 09:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
More later.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310711
09/26/12 09:07 PM
09/26/12 09:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
More later.
Good job Scott... I expect at least 4 to 5 tenths
out of it yet... if you hook
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310712
09/26/12 09:27 PM
09/26/12 09:27 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
More later.
Nice work.. My 400 rwhp at 3500 lbs race weight went 11.48 @ 120, footbraked as well.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: topfueldart] #1310713
09/26/12 09:48 PM
09/26/12 09:48 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Sneaking up on the launch.
Still on 8psi. 11.06@123. 1.74 60 so far with the last 2psi launch.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310714
09/26/12 10:31 PM
09/26/12 10:31 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
Lol awesome. Some folks here just got a lesson in boost
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: j.mcconnell] #1310715
09/26/12 10:46 PM
09/26/12 10:46 PM
mid-mich
turboplymouth Offline
mid-mich
Awesome! Post up your incrementals when you get time. I tried some non sticky radials this year and went 11.00 @ 130 with the same 60' as you, curious to compare.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj. 9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: j.mcconnell] #1310716
09/26/12 10:51 PM
09/26/12 10:51 PM
mid-mich
mid-mich
Yup! I was going to guess 11.00 at 128, but was reluctant to go against the grain, lol.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310717
09/26/12 10:58 PM
09/26/12 10:58 PM
michigan woods
imfixinmopars426 Offline
michigan woods
turbo=good
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310718
09/26/12 11:01 PM
09/26/12 11:01 PM
Out West
408strokerdart Offline
Out West
Still on 8psi. [Email]11.06@123.[/Email] 1.74 60 so far with the last 2psi launch.
Wow...I wasn't even close. Shows how little I know about boosted applications.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: 408strokerdart] #1310719
09/26/12 11:04 PM
09/26/12 11:04 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Me suck too.... Lol
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: B3422W5] #1310720
09/26/12 11:43 PM
09/26/12 11:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I think when he gets it on a good track and turns
up the pressure it will run mid 10s... maybe low 10s
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310721
09/27/12 12:07 AM
09/27/12 12:07 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Nice job Scott!!! Gee i wonder what kind of power it needed to to go 11.0@123 and at 3700lbs????? I think more than just 375.
JAKES AUTOMOTIVE
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310722
09/27/12 12:12 AM
09/27/12 12:12 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The kid let me make the last pass of the night.
60 1.6923
330 4.5902
660 7.0379@100.05
1000 9.1752
1320 10.996@123.65
Lots left,I would venture low tens if the traction stays decent. It stays in 1st gear forever. Thought I missed the shift light. Best comment of the night came from the starting line guy at Milan. "Why did you guys turbo the worlds ugliest car?" I told him because he wanted a fast ugly car.
Doug
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dvw] #1310723
09/27/12 12:38 AM
09/27/12 12:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
60 1.6923
330 4.5902
660 [Email]7.0379@100.05[/Email]
1000 9.1752
1320 [Email]10.996@123.65[/Email]
Doug
Good job... whats the boost at... what will be the
max boost
