Re: Sleeper going to T&T tomorrow. What will it run?!?
[Re: JAKE68]
#1310704
09/26/12 06:50 PM
09/26/12 06:50 PM
Posts: 998 Clinton Township, Michigan
Dartin
Scott, regardless of what it runs, HAVE FUN!!! You've got a cool ride and if it doesn't make the number you're looking for .... It will get there. Randy
[Re: JAKE68]
#1310706
09/26/12 08:00 PM
09/26/12 08:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
This thing had been dynoed and made like 470 at the rear tires, so doing the math not like is real accurate is making around 600+.
470 at the rear wheels is not 600+ HP otherwise I'd be over 600. I just don't see it in that build sorry. It's a very cool car and I hope it runs great. I just don't see 11's. Boost is boost S/C or turbo'd. The gear is going to hurt a bunch. and again I'm not sure how the converter is going to act w/ the boost and the lazy gear. It's like dropping the hammer at 5k in a pedal car w/ a highway gear, the rpms are going to sink way down, when that happens the boost will drop. I'd think it would run a ton better w/ a 3800 stall and 3.55's. I have a buddy that runs 8's at 160+ in a turbo SB. He runs a 4000 stall and 3.73 gears...and that thing has a 700+ lift cam. But hey prove me and a few others wrong and go put up the numbers.
[Re: dizuster]
#1310710
09/26/12 09:01 PM
09/26/12 09:01 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Mr. Yuck. Do you want mustard or catsup with that crow?
Still at Milan. 5th pass, Zero boost launch, 11.30 @ 122 so far on only 8psi. Time to turn up the launch and the boost.
More later.
[Re: dizuster]
#1310711
09/26/12 09:07 PM
09/26/12 09:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
More later.
Good job Scott... I expect at least 4 to 5 tenths out of it yet... if you hook
[Re: dizuster]
#1310712
09/26/12 09:27 PM
09/26/12 09:27 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
More later.
Nice work.. My 400 rwhp at 3500 lbs race weight went 11.48 @ 120, footbraked as well.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: topfueldart]
#1310713
09/26/12 09:48 PM
09/26/12 09:48 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Sneaking up on the launch. Still on 8psi. 11.06@123. 1.74 60 so far with the last 2psi launch.
[Re: j.mcconnell]
#1310715
09/26/12 10:46 PM
09/26/12 10:46 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
Awesome! Post up your incrementals when you get time. I tried some non sticky radials this year and went 11.00 @ 130 with the same 60' as you, curious to compare.
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: dizuster]
#1310718
09/26/12 11:01 PM
09/26/12 11:01 PM
Posts: 3,456 Out West
408strokerdart
Out West
Still on 8psi. [Email]11.06@123.[/Email] 1.74 60 so far with the last 2psi launch.
Wow...I wasn't even close. Shows how little I know about boosted applications.
[Re: MR_P_BODY]
#1310721
09/27/12 12:07 AM
09/27/12 12:07 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Nice job Scott!!! Gee i wonder what kind of power it needed to to go 11.0@123 and at 3700lbs????? I think more than just 375.
JAKES AUTOMOTIVE
[Re: MR_P_BODY]
#1310722
09/27/12 12:12 AM
09/27/12 12:12 AM
Posts: 9,856 MI, usa
dvw
MI, usa
The kid let me make the last pass of the night. 60 1.6923 330 4.5902 660 7.0379@100.051000 9.1752 1320 10.996@123.65Lots left,I would venture low tens if the traction stays decent. It stays in 1st gear forever. Thought I missed the shift light. Best comment of the night came from the starting line guy at Milan. "Why did you guys turbo the worlds ugliest car?" I told him because he wanted a fast ugly car. Doug
[Re: dvw]
#1310723
09/27/12 12:38 AM
09/27/12 12:38 AM
MR_P_BODY
The kid let me make the last pass of the night. 60 1.6923 330 4.5902 660 [Email]7.0379@100.05[/Email] 1000 9.1752 1320 [Email]10.996@123.65[/Email] Lots left,I would venture low tens if the traction stays decent. It stays in 1st gear forever. Thought I missed the shift light. Best comment of the night came from the starting line guy at Milan. "Why did you guys turbo the worlds ugliest car?" I told him because he wanted a fast ugly car. Doug
Good job... whats the boost at... what will be the max boost
