Priming the oil system on a new motor. #1292021
08/26/12 10:34 PM
08/26/12 10:34 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Don't forget to screw on an oil filter or it will be messy .
Fastest 300
Re: Priming the oil system on a new motor. [Re: Crizila] #1292022
08/26/12 10:37 PM
08/26/12 10:37 PM
New York, USA
Chargerfan68 Offline
New York, USA
Or to install the oil pressure send unit before priming.
It maid a nice fountain , though
I can laugh about it now that the mess is cleaned up.
Re: Priming the oil system on a new motor. [Re: Chargerfan68] #1292023
08/26/12 10:47 PM
08/26/12 10:47 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Walked out of my garage in my underware after disgarding my shoes and pants. Naturally I was standing on the oil filter side ( small block ) when I fired up the drill. I did remember to screw in a oil press gauge and I watched the needle not move as I filled up my shoes.
Fastest 300
Re: Priming the oil system on a new motor. [Re: Crizila] #1292024
08/26/12 10:51 PM
08/26/12 10:51 PM
New York, USA
New York, USA
Sorry man, but that is a funny image... Luckily, the oil never made it to me.
Good luck with your motor and start-up.
Re: Priming the oil system on a new motor. [Re: Crizila] #1292025
08/26/12 11:01 PM
08/26/12 11:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That is pretty funny... the other day when I was checking
my lifter in the bores I had my wife hold her finger
over the oil hole on the deck(going to the head).. she
was having a hard time and was loosing oil so I
stopped... as she was standing there I was gonna hit
the drill .... but I didnt... I dont think we would
be married right now if I did....LOL
Re: Priming the oil system on a new motor. [Re: Crizila] #1292026
08/26/12 11:43 PM
08/26/12 11:43 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
John, don't think you're the only one to do that. It's amazing how much oil a Melling high volume oil pump can pump with a 1/2" drill.
I still had mine on jack stands when I did it in 2007. Cold VR1 20w50 is not easy to clean up off of concrete.
Brian Dunnigan
Re: Priming the oil system on a new motor. [Re: '72CudaRacer] #1292027
08/27/12 08:05 AM
08/27/12 08:05 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've done that.
both the oil filter and the oil sending unit.
bad part?
it was on the same engine.
**Photobucket sucks**
Re: Priming the oil system on a new motor. [Re: MR_P_BODY] #1292028
08/28/12 12:00 AM
08/28/12 12:00 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Raff...smart move not to!
Re: Priming the oil system on a new motor. [Re: Crizila] #1292029
08/28/12 01:44 AM
08/28/12 01:44 AM
Murphy loves messin with drag racers Lots of other ways to mess up, I hope you don't find out about any more of them
Re: Priming the oil system on a new motor. [Re: Cab_Burge] #1292030
08/28/12 10:45 AM
08/28/12 10:45 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks. My age is starting to scare me.
Fastest 300
Re: Priming the oil system on a new motor. [Re: Crizila] #1292031
08/28/12 11:57 PM
08/28/12 11:57 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
It's good to know I'm not the only one.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
