Correct Interior Color for 69 GTX
#129139
09/28/08 06:40 PM
09/28/08 06:40 PM
i have a 69 GTX Convert. Having trouble figuring correct interior colors. The exterior is B5 blue. white top. Currently the Dash pad and head rests look like B7, the seats, door panels,doors and carpet are B5. Legendary told me B5 was not a color used for interior seats or carpets for a 69 GTX. My plate reads as follows: 26 END C55 H51 M31 M33 R11 V6W B5 B5 P6D B7 128 173981 E86 D32 RS27 L9G 210285 Anyone help on the correct interior colors??? Thanks
Re: Correct Interior Color for 69 GTX
#129140
09/28/08 06:51 PM
09/28/08 06:51 PM
Posts: 2,234 BFE
vancamp
super street
super street
BFE
yours codes out to be B7 with B7 carpet
VanCamp Dent Systems
Paintless Dent Repair/
Mopar Restification
[Re: vancamp]
#129141
09/28/08 06:58 PM
09/28/08 06:58 PM
Thanks - Are you saying the entire interior should be B7????
[Re: 6bblgt]
#129143
09/28/08 07:37 PM
09/28/08 07:37 PM
Posts: 2,209 NYC
MRVCODE
NYC
My Alpine White 69 GTX convertible has B7 interior, everything is blue, except the carpet Black(4 speed non console car).
[Re: 6bblgt]
#129144
09/28/08 07:55 PM
09/28/08 07:55 PM
I thought the colors were originl BUT I guess not. The upper door frames are B5 blue. The only things that are B7 is the dash pad and the headrests. The convert boot is also B5 so I guess that should also be B7 to match the seats. If the interior is to be all B7, what are the 2 B5 numbers on the plate for?
#129146
09/28/08 10:41 PM
09/28/08 10:41 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
B7 interior is really bright blue. It's not darker blue like the 1969 B7 exterior color. My original carpet with my B7 interior is dark blue. Yours would be too unless you had a 4 speed with no console. Here's a photo of my original (unrestored) upper door and door panels. Maybe what you think is B5 is actually OK?
[Re: RoadRunnerJD]
#129148
09/29/08 05:09 PM
09/29/08 05:09 PM
Legendary Interiors stated that the interior colors for a RR in 69 were not the same as the GTX. If anyone has pictures of a correct interior for the car as described, if you could post them, I would really appreciate it. This is driving me crazy!!
[Re: RoadRunnerJD]
#129150
09/29/08 08:41 PM
09/29/08 08:41 PM
Posts: 17,517 Las Vegas, NV
6bblgt
Las Vegas, NV
1969 Plymouth b-bodyGTX & Sport Satellite - P6D - premium-grade blue buckets Road Runner - H2B - high-grade blue bench & M6B mid-grade blue buckets I know the difference between "P" & "M" is basically the wood grain door panels and dash ... but why the change from "D" to "B" if they are both the same "blue" vinyl? There might be something to the different "blues" but I do not know, does it make any sense? X is black in both S is pewter in both G is green in both T is tan in both H is tan & white in both F is green & white in both W is black & white in both & C is blue & white in both
[Re: 6bblgt]
#129151
09/29/08 09:45 PM
09/29/08 09:45 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
Dan, the "H2B" code interior had a two tone component and a second type of vinyl. As far as M6B...
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#129152
09/29/08 11:29 PM
09/29/08 11:29 PM
6bblgt
Las Vegas, NV
I was cruising "HAMTRAMCK HISTORICAL" and stole the same pics, just didn't get them cut up and posted, that work thing getting in the way again. It's a shame there isn't better/more consistent documented info available to answer questions. I'm still having problems with a P6C interior (blue & white) in a '69 GTX 4-spd (no console) convertible: Are all 4 arm rests white, or are the fronts white & the rears blue? Carpet - blue or black? I think I got this one. - UDF = "B7" & the boot is blue.
[Re: 6bblgt]
#129153
09/29/08 11:40 PM
09/29/08 11:40 PM
6bblgt
Las Vegas, NV
I think the "D" vs. "B" is due to the door panels for the bucket seat Road Runner also having the two-tone blue coloration. JD's pics are RR bucket seat door panels. Correct? Where are your seat pics? Are Road Runner vs. GTX bucket seats different in any way? Seat medallions?
[Re: 6bblgt]
#129155
09/30/08 06:57 AM
09/30/08 06:57 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
P6C - I had one non-console column auto though.
Door panels and all 4 armrests are white, meaning all vinyl door and rear trim panels are white.Including the seats. Carpet, dash and frame,upper-lower door frames,,A-pillar trim, kick panels, steering column, and rear vert panels were B7 blue
[Re: 6bblgt]
#129156
09/30/08 10:45 AM
09/30/08 10:45 AM
RoadRunnerJD
Warrenton, VA
Seats are the same, no medallions, just the plymouth emblem at the top middle of the rear seat back.
[Re: 6bblgt]
#129157
09/30/08 10:51 AM
09/30/08 10:51 AM
RoadRunnerJD
Warrenton, VA
White door panels would have white armrests F & R in a GTX or RR whether it's woodgrain or not and blue door panels will have blue armrests.
Carpet will be black if it's a 4 speed with no console. All automatic and console cars will have dark blue carpet
Re: Correct Interior Color for 69 R/t Coronet
[Re: RoadRunnerJD]
#129158
10/05/11 02:56 PM
10/05/11 02:56 PM
Posts: 1,992 midwest
68427vette
midwest
old post ,revived, but have a question: i just bought a 1969 coronet R/T interior is P6C B7 the fender tag reads: M21 M25 N85 n96 R22 V8W A01 A62 C16 c55 g33 J25 B5 B5 p6C B7 425(date) XXXXXXX E86 D32 ws23 L9G 25XXXX Decoding of Fender Tag: Botttom to Top, Left to Right Code Description: E86 440-4 Barrel High Preformance D32 H-D A-727 TorqueFlite Trans / Some Years A-998 WS23 W = Dodge Coronet / Charger S = Special 23 = 2 Door Hardtop L9G L = 440 375HP 1-4BBL 8 CYL 9 = 1969 G = St. Louis, MO, USA 255XXX Sequence Number '255XXX' EB5 Paint Code: Bright Blue Metallic / Blue Fire Irid P6C Trim Grade/Style/Color P = Premium 6 = Vinyl Bucket Seats C = Blue and White B7 Upper Door Frame: Medium Blue Metallic 425 Date Built: 4 / 25 / 1969 220XXX Order Number: 220XXX A01 Roof Type OR Color: Light Package A62 Rallye Instrument Cluster C16 Console w/ Buckets C55 Bucket Seats G33 Left Hand Outside Mirror - Manual / Chrome J25 3 Speed Variable Wipers M21 Roof Drip Rail Moldings M25 Wide Sill Molding N85 Tachometer N96 Fresh Air Hood R22 AM w/ 8-Track V8W Transverse Stripe - White END End of Codes car has white door panels, B5 blue painted top? no vinyl , not convertible. what is supposed to be white,, and carpet color? dash is darker blue B7 door panels are white, console?? arm rest? any help thanks jc http://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1969/69_Coronet0003.jpghttp://www.hamtramck-historical.com/dealerships/1969ColorAndTrim-03.shtml
