Correct Interior Color for 69 GTX #129139
09/28/08 06:40 PM
09/28/08 06:40 PM
Anonymous OP
Anonymous OP
i have a 69 GTX Convert. Having trouble figuring correct interior colors. The exterior is B5 blue. white top. Currently the Dash pad and head rests look like B7, the seats, door panels,doors and carpet are B5. Legendary told me B5 was not a color used for interior seats or carpets for a 69 GTX. My plate reads as follows:
26 END
C55 H51 M31 M33 R11 V6W
B5 B5 P6D B7 128 173981
E86 D32 RS27 L9G 210285
Anyone help on the correct interior colors???
Re: Correct Interior Color for 69 GTX #129140
09/28/08 06:51 PM
09/28/08 06:51 PM
BFE
vancamp Offline
super street
vancamp  Offline
super street
BFE
yours codes out to be B7 with B7 carpet
VanCamp Dent Systems Paintless Dent Repair/ Mopar Restification
Re: Correct Interior Color for 69 GTX [Re: vancamp] #129141
09/28/08 06:58 PM
09/28/08 06:58 PM
Anonymous OP
Anonymous OP
Thanks - Are you saying the entire interior should be B7????
Re: Correct Interior Color for 69 GTX #129142
09/28/08 07:08 PM
09/28/08 07:08 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
P6D B7
Your interior decodes as:
P6D - "premuim grade, vinyl bucket seat interior - BLUE"
B7 - Upper Door Frame paint - "Jamaica Blue metallic"
There was only one blue bucket seat interior available in a Plymouth b-body in 1969.
The door frame color gives you an indication of the light or darkness of the overall scheme, but many shades of blue will be found.
Legendary usually has the most accurate reproduction interior available.
Is your interior original or have pieces been replaced/repaired over the years?
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129143
09/28/08 07:37 PM
09/28/08 07:37 PM
NYC
MRVCODE Offline
MRVCODE  Offline
NYC
My Alpine White 69 GTX convertible has B7 interior, everything is blue, except the carpet Black(4 speed non console car).
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129144
09/28/08 07:55 PM
09/28/08 07:55 PM
Anonymous OP
Anonymous OP
I thought the colors were originl BUT I guess not. The upper door frames are B5 blue. The only things that are B7 is the dash pad and the headrests. The convert boot is also B5 so I guess that should also be B7 to match the seats. If the interior is to be all B7, what are the 2 B5 numbers on the plate for?
Re: Correct Interior Color for 69 GTX #129145
09/28/08 08:04 PM
09/28/08 08:04 PM
Indianpolis, IN
69_500 Offline
69_500  Offline
Indianpolis, IN
The two B5 numbers on the tag are for the body.
Re: Correct Interior Color for 69 GTX #129146
09/28/08 10:41 PM
09/28/08 10:41 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
B7 interior is really bright blue. It's not darker blue like the 1969 B7 exterior color. My original carpet with my B7 interior is dark blue. Yours would be too unless you had a 4 speed with no console. Here's a photo of my original (unrestored) upper door and door panels. Maybe what you think is B5 is actually OK?
Re: Correct Interior Color for 69 GTX [Re: RoadRunnerJD] #129147
09/28/08 10:42 PM
09/28/08 10:42 PM
Warrenton, VA
Warrenton, VA
Here's my dash. Again, this is the B7 blue interior in my 1969 Road Runner. The paint code for the interior paint is called Baltic Blue. Of course, you will have a different mix for the A pillar plastic pieces. The mix is lacquer and should have a "V" suffix for vinyl. The dash is called "Suede" and is originally a lacquer paint. The doors and rear side panels are probably a semi-gloss enamel or gloss with some flattener? I left my doors and rear panels in original paint because it has a certain "patina" to it that repainted interiors just can't match and I could live with the minor wear on them.
Re: Correct Interior Color for 69 GTX [Re: RoadRunnerJD] #129148
09/29/08 05:09 PM
09/29/08 05:09 PM
Anonymous OP
Anonymous OP
Legendary Interiors stated that the interior colors for a RR in 69 were not the same as the GTX. If anyone has pictures of a correct interior for the car as described, if you could post them, I would really appreciate it. This is driving me crazy!!
Re: Correct Interior Color for 69 GTX #129149
09/29/08 07:39 PM
09/29/08 07:39 PM
Warrenton, VA
Warrenton, VA
The only thing different in the interior is the GTX woodgrain door panels and trim on the dash. I am pretty certain that the paint colors, dash pads and seats will be the same.
Re: Correct Interior Color for 69 GTX [Re: RoadRunnerJD] #129150
09/29/08 08:41 PM
09/29/08 08:41 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
1969 Plymouth b-body
GTX & Sport Satellite - P6D - premium-grade blue buckets
Road Runner - H2B - high-grade blue bench & M6B mid-grade blue buckets
I know the difference between "P" & "M" is basically the wood grain door panels and dash ...
but why the change from "D" to "B" if they are both the same "blue" vinyl?
There might be something to the different "blues" but I do not know, does it make any sense?
X is black in both
S is pewter in both
G is green in both
T is tan in both
H is tan & white in both
F is green & white in both
W is black & white in both
C is blue & white in both
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129151
09/29/08 09:45 PM
09/29/08 09:45 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Dan, the "H2B" code interior had a two tone component and a second type of vinyl. As far as M6B...
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: Correct Interior Color for 69 GTX [Re: 69CoronetRT] #129152
09/29/08 11:29 PM
09/29/08 11:29 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I was cruising "HAMTRAMCK HISTORICAL" and stole the same pics, just didn't get them cut up and posted, that work thing getting in the way again.
It's a shame there isn't better/more consistent documented info available to answer questions.
I'm still having problems with a P6C interior (blue & white) in a '69 GTX 4-spd (no console) convertible:
Are all 4 arm rests white, or are the fronts white & the rears blue?
Carpet - blue or black?
I think I got this one. - UDF = "B7" & the boot is blue.
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129153
09/29/08 11:40 PM
09/29/08 11:40 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I think the "D" vs. "B" is due to the door panels for the bucket seat Road Runner also having the two-tone blue coloration.
JD's pics are RR bucket seat door panels. Correct? Where are your seat pics?
Are Road Runner vs. GTX bucket seats different in any way? Seat medallions?
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129154
09/30/08 12:06 AM
09/30/08 12:06 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Parts book shows pads are white and both white and blue boots are listed for P6C.
Here's P6V in a Coronet. I assume the color scheme is similar for P6C GTXs. (blue rear panels with white pads; blue seatbelts. I'm too lazy to look up all the PNs)
Seeking:
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129155
09/30/08 06:57 AM
09/30/08 06:57 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
P6C - I had one non-console column auto though.
Door panels and all 4 armrests are white, meaning all vinyl door and rear trim panels are white.Including the seats.
Carpet, dash and frame,upper-lower door frames,,A-pillar trim, kick panels, steering column, and rear vert panels were B7 blue
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129156
09/30/08 10:45 AM
09/30/08 10:45 AM
Warrenton, VA
Warrenton, VA
Seats are the same, no medallions, just the plymouth emblem at the top middle of the rear seat back.
Re: Correct Interior Color for 69 GTX [Re: 6bblgt] #129157
09/30/08 10:51 AM
09/30/08 10:51 AM
Warrenton, VA
Warrenton, VA
White door panels would have white armrests F & R in a GTX or RR whether it's woodgrain or not and blue door panels will have blue armrests.
Carpet will be black if it's a 4 speed with no console. All automatic and console cars will have dark blue carpet
Re: Correct Interior Color for 69 R/t Coronet [Re: RoadRunnerJD] #129158
10/05/11 02:56 PM
10/05/11 02:56 PM
midwest
68427vette Offline
68427vette  Offline
midwest
old post ,revived, but have a question:
i just bought a 1969 coronet R/T interior is P6C B7
the fender tag reads:
M21 M25 N85 n96 R22 V8W
A01 A62 C16 c55 g33 J25
B5 B5 p6C B7 425(date) XXXXXXX
E86 D32 ws23 L9G 25XXXX
Decoding of Fender Tag: Botttom to Top, Left to Right
Code Description:
E86 440-4 Barrel High Preformance
D32 H-D A-727 TorqueFlite Trans / Some Years A-998
WS23 W = Dodge Coronet / Charger
S = Special
23 = 2 Door Hardtop
L9G L = 440 375HP 1-4BBL 8 CYL
9 = 1969
G = St. Louis, MO, USA
255XXX Sequence Number '255XXX'
EB5 Paint Code: Bright Blue Metallic / Blue Fire Irid
P6C Trim Grade/Style/Color
P = Premium
6 = Vinyl Bucket Seats
C = Blue and White
B7 Upper Door Frame: Medium Blue Metallic
425 Date Built: 4 / 25 / 1969
220XXX Order Number: 220XXX
A01 Roof Type OR Color: Light Package
A62 Rallye Instrument Cluster
C16 Console w/ Buckets
C55 Bucket Seats
G33 Left Hand Outside Mirror - Manual / Chrome
J25 3 Speed Variable Wipers
M21 Roof Drip Rail Moldings
M25 Wide Sill Molding
N85 Tachometer
N96 Fresh Air Hood
R22 AM w/ 8-Track
V8W Transverse Stripe - White
END End of Codes
car has white door panels, B5 blue painted top? no vinyl , not convertible.
what is supposed to be white,, and carpet color? dash is darker blue B7
door panels are white, console?? arm rest? any help thanks
jc
http://www.hamtramck-historical.com/images/dealerships/colorAndTrim/1969/69_Coronet0003.jpg
http://www.hamtramck-historical.com/dealerships/1969ColorAndTrim-03.shtml
