Thermoquad repair - throttle shaft loose
#1285762
08/15/12 02:33 PM
08/15/12 02:33 PM
Posts: 31 Two Harbors, MN
chrgr340
Two Harbors, MN
The throttle shaft on my TQ is loose to the point that it leaks gas out both sides of the carb. After some searching, I see that they can apparently be bushed.
- Is this something that can easily be done at home by myself?
- Are there any pros out there that I can send my carb to that can repair this and go through the whole carb for a reasonable price?
1972 Dodge Charger - F7, Rallye pkg, 340, A833 2007 Dodge Charger R/T R&T - 12sec daily beater 1999 Dodge Dakota R/T - M1, cam, heads, T56 swap 1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
Re: Thermoquad repair - throttle shaft loose
[Re: chrgr340]
#1285763
08/15/12 02:43 PM
08/15/12 02:43 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I've Google'd this repair in the past and found several places that will do it for you, or they will send you a kit to do it yourself.
For more hits on Google, it's a common repair on Rochester carbs as well.
It's helpful if you have a drill press to do the work though.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: ScottSmith_Harms]
#1285765
08/16/12 08:34 PM
08/16/12 08:34 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
All carbs AFAIK have this problem. I need to rebush a bunch! Two drill presses. Just bought a BBD that the shaft pops in and out 1/4"???
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
