Thermoquad repair - throttle shaft loose #1285762
08/15/12 02:33 PM
08/15/12 02:33 PM
Two Harbors, MN
chrgr340 Offline OP
chrgr340  Offline OP
Two Harbors, MN
The throttle shaft on my TQ is loose to the point that it leaks gas out both sides of the carb. After some searching, I see that they can apparently be bushed.
- Is this something that can easily be done at home by myself?
- Are there any pros out there that I can send my carb to that can repair this and go through the whole carb for a reasonable price?
1972 Dodge Charger - F7, Rallye pkg, 340, A833
2007 Dodge Charger R/T R&T - 12sec daily beater
1999 Dodge Dakota R/T - M1, cam, heads, T56 swap
1997 Dodge Dakota - 318, NV3500, 3.92 Sure Grip
Re: Thermoquad repair - throttle shaft loose [Re: chrgr340] #1285763
08/15/12 02:43 PM
08/15/12 02:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've Google'd this repair in the past and found several places that will do it for you, or they will send you a kit to do it yourself.
For more hits on Google, it's a common repair on Rochester carbs as well.
It's helpful if you have a drill press to do the work though.
Re: Thermoquad repair - throttle shaft loose [Re: jbc426] #1285764
08/15/12 03:03 PM
08/15/12 03:03 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you need your carb restored I'll be glad to help you, rebushing the throttle shaft bores is part of my typical restoration service. I am very familiar with Thermo-Quad carburetors so no worries. If you have any questions feel free to call 801-940-2689 Scott
Re: Thermoquad repair - throttle shaft loose [Re: ScottSmith_Harms] #1285765
08/16/12 08:34 PM
08/16/12 08:34 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
All carbs AFAIK have this problem. I need to rebush a bunch! Two drill presses.
Just bought a BBD that the shaft pops in and out 1/4"???
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
