100K Refresh
#1283701
08/11/12 07:46 PM
08/11/12 07:46 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
My trusty pickup just rolled 100,000 happy miles the other day and I figured I would reward it with a freshening up. It doesnt need anything but I want it to feel like new so Im thinking... -shocks -new plugs (still has the originals) -complete transmission flush (never did that before)
I thought about pulling the injectors and cleaning them but I put a bottle of STP injector cleaner in the tank at every oil change, should I do it anyway because of the E10?
I just did the ball joints and wheel bearings last year and replaced 2 brake rotors. Anything else Im missing?
its a 2004 Ram 1500 Hemi 4X4
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
Re: 100K Refresh
[Re: mcmopars]
#1283703
08/11/12 09:00 PM
08/11/12 09:00 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Unless you want to be rebuilding the trans in a few months don't do the flush... Drain, replace the filter & refill only....
Re: 100K Refresh
[Re: 1_WILD_RT]
#1283704
08/12/12 09:58 AM
08/12/12 09:58 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Dan how often do you change the trans fluid ?
Re: 100K Refresh
[Re: gch]
#1283706
08/12/12 02:06 PM
08/12/12 02:06 PM
RangerDan440
oops, I meant to say I add injector cleaner at every oil change, not every fill up. And I do oil changes and inspect all the fluids, filters and hoses every 5000 miles.
John I tow a lot with the truck so I change the fluid and filters every 30K.
Why are complete trans flushes bad?
Re: 100K Refresh
[Re: RangerDan440]
#1283707
08/12/12 02:16 PM
08/12/12 02:16 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I agree with flushing the brake fluid. I have flushed some where the fluid looked like chocolate milk. Replace Fuel filter, and PCV too. Don't flush trans, just drain, replace filter and new fluid. Shocks yes, plugs yes, If distrubitor, cap and rotor, plug wires. If you do regular oil changes the inside of the engine should be pretty clean, but if there is alot of buildup you may want to run a can of the gunk motor flush before changing the oil.
Re: 100K Refresh
[Re: RangerDan440]
#1283708
08/12/12 02:17 PM
08/12/12 02:17 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
When was the last time you changed the differential and brake fluids?
MB suggests a brake fluid flush every 20,000 miles. Gear oil is around 50k if I remember correctly.
