100K Refresh #1283701
08/11/12 07:46 PM
08/11/12 07:46 PM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline OP
My trusty pickup just rolled 100,000 happy miles the other day and I figured I would reward it with a freshening up. It doesnt need anything but I want it to feel like new so Im thinking...
-shocks
-new plugs (still has the originals)
-complete transmission flush (never did that before)
I thought about pulling the injectors and cleaning them but I put a bottle of STP injector cleaner in the tank at every oil change, should I do it anyway because of the E10?
I just did the ball joints and wheel bearings last year and replaced 2 brake rotors. Anything else Im missing?
its a 2004 Ram 1500 Hemi 4X4
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
71 Country Squire 351W
71 Road Runner 440+6
71 Satellite sedan 318
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
10 Challenger R/T M6
15 Challenger Hellcat M6
Re: 100K Refresh [Re: RangerDan440] #1283702
08/11/12 08:15 PM
08/11/12 08:15 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
it depends on what a refresh is.tune-up?fluids? suspension? etc.
Re: 100K Refresh [Re: mcmopars] #1283703
08/11/12 09:00 PM
08/11/12 09:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Unless you want to be rebuilding the trans in a few months don't do the flush... Drain, replace the filter & refill only....
Re: 100K Refresh [Re: 1_WILD_RT] #1283704
08/12/12 09:58 AM
08/12/12 09:58 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dan how often do you change the trans fluid ?
Re: 100K Refresh [Re: JohnRR] #1283705
08/12/12 01:58 PM
08/12/12 01:58 PM
Central NC
gch Offline
gch  Offline
Central NC
Maybe check the condition of the brake fluid,power steering fluid,and the coolant.Some replacing/refreshing there is a good idea.Look real good at the radiator/heater hoses for problems down the road.
Definitely do the plugs.Clean the mass air flow and throttle body and throw in a new o2 sensor if you feel froggy.
Definitely a drain and fill on the tranny.Flush=no good.
Would'nt touch the injectors with all the additive you run.too much IMO.
Re: 100K Refresh [Re: gch] #1283706
08/12/12 02:06 PM
08/12/12 02:06 PM
oops, I meant to say I add injector cleaner at every oil change, not every fill up. And I do oil changes and inspect all the fluids, filters and hoses every 5000 miles.
John I tow a lot with the truck so I change the fluid and filters every 30K.
Why are complete trans flushes bad?
68 Valiant 408
69 Charger 318
69 Cougar 351W
70 Torino GT 351C
73 Duster 318
73 Challenger 383
77 Grand Prix 455
83 Malibu 9C1 383
84 Delta 88 403
87 Grand National
96 Ram 360
09 Crown Vic
Re: 100K Refresh [Re: RangerDan440] #1283707
08/12/12 02:16 PM
08/12/12 02:16 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I agree with flushing the brake fluid. I have flushed some where the fluid looked like chocolate milk. Replace Fuel filter, and PCV too. Don't flush trans, just drain, replace filter and new fluid. Shocks yes, plugs yes, If distrubitor, cap and rotor, plug wires.
If you do regular oil changes the inside of the engine should be pretty clean, but if there is alot of buildup you may want to run a can of the gunk motor flush before changing the oil.
Re: 100K Refresh [Re: RangerDan440] #1283708
08/12/12 02:17 PM
08/12/12 02:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
When was the last time you changed the differential and brake fluids?
MB suggests a brake fluid flush every 20,000 miles. Gear oil is around 50k if I remember correctly.
- Stu Harmon
Re: 100K Refresh [Re: feets] #1283709
08/12/12 06:15 PM
08/12/12 06:15 PM
Central NC
gch Offline
gch  Offline
Central NC
To my knowledge a trans flush machine flushes the fluid bacwards through the trans.I may be wrong on this but if not the fluid was designed to go one way and thats the way I want it going.I can see gunk,deposits,or whatever being broken loose and causing a problem.
