Page 3 of 3 1 2 3
Re: 1970 LAPD Belvedere [Re: hergfest] #1282740
08/13/12 02:21 PM
08/13/12 02:21 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
I don't think this car was LAPD.
Assuming that is a real police package car, I would at least question whether LAPD ever bought that particular year/model. I was on LAPD (10 years later) and I never heard of or saw any 1970s of that model, although I did see/drive vehicles from that era, some at the police driving school, where they retained some hot, older cars, and there were a couple of oldies still out in the field. I don't know if LAPD has made records of their vehicle purchases available, but if so I would check there first.
Re: 1970 LAPD Belvedere [Re: GreenBird] #1282741
08/21/12 04:46 PM
08/21/12 04:46 PM
California
70plumdart Offline
70plumdart  Offline
California
Hi all,
I'm new here.
I've looked at this car. It appears to be a real police car.. replacement motor, needs paint, could be Lapd car. Fender tag does not yield a lot. B7 color
Rkrqn0a188xxxx
Any guesstimate of its real value?
1970 RR A13 1970 Dart 1971 Dart 1970 Duster
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282742
08/21/12 05:08 PM
08/21/12 05:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Hi all,
I'm new here.
Rkrqn0a188xxxx
Does it have a rear sway bar? Details on condition? Rust or rust repair? Drivability?
Tough to find comparable police car sales. Personally I like to put cars like that in rank order between other car that are easier to pinpoint values to. IMHO it's worth less than a 70 Road Runner column shift ok color in the same condition. Is it worth less/more than a 70 Sport Satelite 2 door N code car same codition?
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282743
08/21/12 06:48 PM
08/21/12 06:48 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Can anyone ID this rear sway bar in Shankers car as a original part
https://board.moparts.org/ubbthreads/show...part=3&vc=1
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282744
08/21/12 09:08 PM
08/21/12 09:08 PM
California
70plumdart Offline
70plumdart  Offline
California
The car is a driver. Yes it has a rear sway bar, although it looks aftermarket. Couldn't get under it enough to see the upper arch to see if there were factory fasteners.
Photos at start of thread accurately represent the car. Some rust in floor not too bad.
So: 5k...5.5k.....6k.?????
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282745
08/21/12 10:12 PM
08/21/12 10:12 PM
New England
Q5_Ed Offline
Q5_Ed  Offline
New England
5K
WANTED : ...A New Sponsor or Winning Lottery Ticket 69 A12 road runner ,Q5, post coupe, 4 speed, former Drag car restored to "Driver" condition in the early 90's, Showing some Patina. SS/E Track Record Holder 1980 10.40 @ 130mph
Re: 1970 LAPD Belvedere [Re: Alaskan_TA] #1282746
08/24/12 11:22 PM
08/24/12 11:22 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Can you get a clear photo of the whole tag?
Clear photo of whole tag...
Re: 1970 LAPD Belvedere [Re: autoxcuda] #1282747
08/26/12 12:07 PM
08/26/12 12:07 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
My first car was a ex cop 7o belvedere. Bought it in 73 for $143 with burnt valves, slipping 727 and a broken torsion bar. Motor was base-line 2bbl, non ac, front, but no rear sway bar. The torsion bars werehd (hemi) and there was extra reinforcement. All very similar to this car yet came with black exterior, white overpainted doors and top. Tan interior and rubber floor "carpet". It had a driver side spotlight and a antenna mast delete plate that, iirc, was a piece of metal formed to fit flush but was screwed on from a single stud spot welded onto the underside.
If I wasn't in the process of moving I'd be looking seriously at that car (except for the rust issue it's a nice offering).
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282748
09/07/12 12:27 AM
09/07/12 12:27 AM
California
70plumdart Offline
70plumdart  Offline
California
Does anyone know what the correct front and rear sway bars are on a 70 Belvedere LAPD car? Is there any listing in the parts book?
Build sheet has two notes:
"Heavy duty frt & rr"
"RR sway bars"
Any help appreciated. Also, if you know where I can locate the rear bar and attachments please let me know.
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282749
09/07/12 02:05 PM
09/07/12 02:05 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
If you are still trying to determine whether or not that actually was an LAPD car, you might try contacting the LAPD historical society and asking if they have VIN records of former department cars and, if not, where those records might be.
http://www.laphs.org/
Re: 1970 LAPD Belvedere [Re: GreenBird] #1282750
09/07/12 03:26 PM
09/07/12 03:26 PM
California
70plumdart Offline
70plumdart  Offline
California
Thanks for the info. LAPD has no info these cars. Neither does the historical society. Which is too bad. Dmv purged all old records some time ago. They no longer do this but its all gone for the early 70s. SID Photos is the only place that has any info. They have a pretty good photo collection of old police cars and equipment.
As for the car this thread started with, I don't know if it still for sale. After a lot of looking and research, the jury is still out if it is a genuine LAPD car, might be - might not..
I did purchase a Belvedere which definitely could be a LAPD car. Drums all around, no rear defroster, factory sway bars, possible shop numbers on license plate holder and several other indicators, I'll know more when it's in my garage.
I do need green steering wheel with full circle horn ring for the new ride.
Re: 1970 LAPD Belvedere [Re: GreenBird] #1282751
09/07/12 03:58 PM
09/07/12 03:58 PM
STL
cdstl Offline
cdstl  Offline
STL
I bought a 74 Fury 3 cop car that was used as a city car for the town of Morrison, IL. 440, steel crank, 6 pack rods, TQ and webbing on the block. Polyglass pursuit radials and special suspension are a few tidbits that I remember. It also had a vernier-type cable to the carb mounted under the dash. I was told it was so the trooper could idle the engine up while sitting to aid with engine cooling. My mom told me to just keep that and sell the 67 RT Coronet. Probably would have been a good idea.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: 1970 LAPD Belvedere [Re: cdstl] #1282752
10/04/12 02:11 AM
10/04/12 02:11 AM
New State
kidmopar Offline
kidmopar  Offline
New State
Holy Cop Cars! ....... It's Back!
web page
Re: 1970 LAPD Belvedere [Re: kidmopar] #1282753
10/18/12 08:26 PM
10/18/12 08:26 PM
California
70plumdart Offline
70plumdart  Offline
California
Hi,
the green belvedere from new york got here and I am happy to say I found the LAPD shop number exactly where they were written on the rear license plate holder.
The blue Pasadena belvedere was relisted on craigslist on Sunday. It was sold two week ago and picked up today. So its gone..... gone to my driveway!
so I guess I own two k code 70 belvederes. I'll drive the blue one while I fix the LAPD one...
The blue one drives just like I remember.
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282754
10/19/12 01:21 PM
10/19/12 01:21 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
Wow..two Belvederes in one month. Congrats and post a few pics when you get the chance...
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: 1970 LAPD Belvedere [Re: 68 Sat] #1282755
04/14/13 01:15 AM
04/14/13 01:15 AM
California
70plumdart Offline
70plumdart  Offline
California
Hi all,
Drove the blue 70 Belvedere today. Got siren, lights and radios in. Fixed all the problems like holes in floor and moved aftermarket amplifier.
Car drives good and seems to in mechanically sound shape.
I'm going to start on other 70 Belvedere after I finish putting the engine in the 73 police package matador.
Turns out the green Belvedere has a LAPD shop number on rear license plate holder. I'm collecting parts now.
Big news is the LAPD car had a single rear California blue and yellow plate in trunk. It also had 15 years of registration cards from 1971 thru 1980s. These reg cards had the plate number the same as the one in trunk. I was whining to my friend who sold me the car if I only had the front plate. He did. I was able to register the car with the original California plates issued in 1970!
More later.
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282756
04/15/13 09:20 PM
04/15/13 09:20 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
those cars were called 4 door roadrunners by the guys that drove them--also there is more to LA than LAPD there is also the LA sheriff and 50 other citys in the megopolis--most state police would write specs on cars ordered then get the bids and smaller juristictions could add their orders on with the same specs and the same price---chrysler at that time was showing about $100 dollar profit for the dealer that sold the cars because they wanted their cars out there in the public domain---sort of like what wins on sunday sells on monday....bob
Re: 1970 LAPD Belvedere [Re: savoy64] #1282757
04/15/13 11:55 PM
04/15/13 11:55 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Colorado's state bid priced many different types and styles on police packages that, as bob pointed out, could be bid by any local government agencies. The state itself bought Fury Is for the patrol. It had an interesting option that included the factory installing an NMO (new Motorola) 3/4" antenna mount in the roof center but no antenna. The coax ran down the rear pillar to the trunk where it was coiled and unterminated. The radio installers at 4201 E Arkansas would mount a Larsen 5/8 wave antenna on the roof and install a 110 Watt Motorola Motrac in the trunk. I never saw that antenna option on the Belvederes or on any of the municipal orders in Colorado.
Denver Police never ordered police package cars and drove standard grocery getter Fords off the fleet lot with few heavy duty items on them.
Craig
Re: 1970 LAPD Belvedere [Re: 70plumdart] #1282758
04/22/13 02:26 PM
04/22/13 02:26 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Hi all,
Wow. That sounds like a great project. Obviously I was wrong on my earlier post speculating about whether LAPD ever bought 70 Belvederes. I have since seen a photo on some website (I should have bookmarked but failed to do so) of such an LAPD car.
Also, re: your comment about restoring a 73 Matador as well, I did drive one of the Matadors at the police driving school and in Hollywood Division, where we had a dual purpose Matador (I think it was green), and those were definitely great police cars.
If you ever want to sell either of those, send me a message. Those are important pieces of police history and it is great to see you are preserving them. My wife, who also was an LAPD officer in Hollywood and worked on the vice detail, jokingly (I think) wanted me to buy an ex-LAPD B-Wagon of the type that was used to round up prostitutes on Sunset Blvd, drunks elsewhere, etc. I was less enthusiastic because the B-Wagons were not exactly hot rods.
Page 3 of 3 1 2 3
