If you do go back to the stick you will need to use a adjustable clutch switch. The factory switch will not work. You need to be able to time the nos so that it comes on as the clutch engages. If it comes on to soon the rpms will spike and spin the tires or slip the clutch, to late and you will bogg off the line before the nos comes on. I set mine at 20 thou air gap and it worked fine. Hope this helps
Donald
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
