vinyl top and windshield trim #1273688
07/23/12 08:46 PM
07/23/12 08:46 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
I was wondering if there's a technique that's used to reduce the "Bump" of the vinyl top seam. I'm putting on the windshield trim and have notice that the upper corner is being difficult due to the vinyl trim... Do you "help" thin out the seam so there isn't so much of an obstruction to the curve of the trim. Everything else seems to be perfect on all the other parts of the moulding top and bottom.
Thanks..
Troy
Houston Mopar Connection Club
Re: vinyl top and windshield trim [Re: hemi68charger] #1273689
07/23/12 08:52 PM
07/23/12 08:52 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I took a hammer and blunt punch to mine to pound it just a little flatter--made a difference.
Re: vinyl top and windshield trim [Re: Pacnorthcuda] #1273690
07/23/12 08:59 PM
07/23/12 08:59 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You can trim the top layer away too. Just make sure you do it low enough so you don't see it.
Re: vinyl top and windshield trim [Re: burdar] #1273691
07/24/12 02:56 PM
07/24/12 02:56 PM
Houston, Tx
Houston, Tx
Thanks guys.. Did exactly that and it worked.... Now, does anyone know if there's a screw kit that includes the proper fasteners for the bottom windshield trim plate?
Troy
Re: vinyl top and windshield trim [Re: hemi68charger] #1273692
07/25/12 05:05 PM
07/25/12 05:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
http://www.ebay.com/itm/230402429515?item=230402429515&viewitem=&vxp=mtr
Re: vinyl top and windshield trim [Re: gtx6970] #1273693
07/25/12 07:33 PM
07/25/12 07:33 PM
Houston, Tx
Houston, Tx
Dang Bill... You have everything..... Guess I'll order these and pay for the brake bracket too.. But, I think there might be other stuff I'll need to get as I go along this process.... Headliner c-clips for the outside edge/pinch, got 'em?
Troy
Re: vinyl top and windshield trim [Re: hemi68charger] #1273694
07/26/12 02:57 AM
07/26/12 02:57 AM
fiddlerfingers Offline
www.rtspecialties.net has about everything you will need when it comes to correct nuts/bolts/clips.
Re: vinyl top and windshield trim [Re: hemi68charger] #1273695
07/26/12 07:27 AM
07/26/12 07:27 AM
western australia
1cuda Offline
1cuda  Offline
western australia
only because of the pic you posted but the plastic grilles that cover the wiper areas on the cowl had little hex self tapping screws in 1970 and 1971 had phillips head screws-can someone confirm this?
all the best
frank
Re: vinyl top and windshield trim [Re: hemi68charger] #1273696
07/26/12 09:47 AM
07/26/12 09:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
That might be a bit of a stretch
Nope
This kit is everything needed to attach the lower windshield stainless trim and both wiper pivots.
Cowl vent plastic grilles on my old 1970 Challenger used pan head phillips screws, 71's I have hard were hex head screws with a shoulder under the head
Re: vinyl top and windshield trim [Re: gtx6970] #1273697
07/26/12 07:18 PM
07/26/12 07:18 PM
western australia
1cuda Offline
1cuda  Offline
western australia
i knew it was one or the other between 70 and 71-thanx gtx6970.
that 71 challenger looks like it`s coming together great
keep the pics coming.
all the best
frank.
