Re: Hemi oil P/U tube broke off !
[Re: Lee446]
#1267977
07/15/12 12:05 AM
07/15/12 12:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
At the threads are the weak point to begin with... it could be just a fluke ... but I would say the bottom of the pick up is moving to crack it off ... you might want to put something on to stiffen it so it cant move
[Re: Lee446]
#1267979
07/15/12 03:12 PM
07/15/12 03:12 PM
Posts: 25,967 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The instructions with the MP Hemi pickup state that it can be installed so that it's just touching the bottom of the pan or up to 1/4" clearance.
With clearance the whole tube is subject to the thrashing inside the lower block that stresses the threads on the end of the tube; with it just touching the bottom it gives support so that it isn't stressing the threads as much.
[Re: John_Kunkel]
#1267980
07/15/12 04:29 PM
07/15/12 04:29 PM
MR_P_BODY
With clearance the whole tube is subject to the thrashing inside the lower block that stresses the threads on the end of the tube; with it just touching the bottom it gives support so that it isn't stressing the threads as much. [/quote
Might even weld 2 or 3 short stanchions on the bottom of the pan to hold it in location (put clay on the pan and install the pan to get the proper pick up location)
[Re: Challenger 1]
#1267985
07/18/12 09:59 PM
07/18/12 09:59 PM
Posts: 2,052 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
If you go with an external system, it doesn't have to be elaborate, a fixed pick up with a single line to a Milodon oil pump cover with provisions for a remote oil filter. Simple, looks cool as heck, adds about a quart and a half of oil capacity, the pan is a breeze to take off and put on, and when you change oil theres no mess from the filter laying on its side. Just a thought.
Brian Dunnigan
