Hemi oil P/U tube broke off ! #1267976
07/14/12 11:38 PM
07/14/12 11:38 PM
Houston,Tx.
Lee446 Offline OP
Lee446  Offline OP
Houston,Tx.
I noticed my oil pressure fluctuating while I was driving. All of the sudden I saw it drop and my oil lite came on as I shut the engine off. I fired it back up for about 5 seconds to get off the street and verify that it was not a gauge malfunction. I called for a rollback to take it home. Today, I went ahead and pulled the pan. Sure enough, the pickup had broken off flush with the block. This is a 528 Hemi that was built by one of the best. I can find no signs of external damage to the tube, no marks or gouges and I would be surprised if I had. The pan and pickup are the MP Hemi pan and 1/2" p/u that originally came on the engine. I have a Moroso deep pan and p/u that I can put on, or should I just get another MP pickup? Did they ever have any defective P/Ups or is this just a fluke? I'm open to suggestions! Thanks, Lee.
Re: Hemi oil P/U tube broke off ! [Re: Lee446] #1267977
07/15/12 12:05 AM
07/15/12 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
At the threads are the weak point to begin with...
it could be just a fluke ... but I would say the bottom
of the pick up is moving to crack it off ... you might
want to put something on to stiffen it so it cant move
Re: Hemi oil P/U tube broke off ! [Re: MR_P_BODY] #1267978
07/15/12 09:55 AM
07/15/12 09:55 AM
Iowa
coronetville Offline
Iowa
Invest money in external oil system. A hemi carries 5 qts. of oil in the heads at 7000 rpms. You already had your warning
Re: Hemi oil P/U tube broke off ! [Re: Lee446] #1267979
07/15/12 03:12 PM
07/15/12 03:12 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The instructions with the MP Hemi pickup state that it can be installed so that it's just touching the bottom of the pan or up to 1/4" clearance.
With clearance the whole tube is subject to the thrashing inside the lower block that stresses the threads on the end of the tube; with it just touching the bottom it gives support so that it isn't stressing the threads as much.
Re: Hemi oil P/U tube broke off ! [Re: John_Kunkel] #1267980
07/15/12 04:29 PM
07/15/12 04:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With clearance the whole tube is subject to the thrashing inside the lower block that stresses the threads on the end of the tube; with it just touching the bottom it gives support so that it isn't stressing the threads as much. [/quote
Might even weld 2 or 3 short stanchions on the bottom
of the pan to hold it in location (put clay on the
pan and install the pan to get the proper pick up
location)
Re: Hemi oil P/U tube broke off ! [Re: coronetville] #1267981
07/15/12 04:30 PM
07/15/12 04:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I had this happen TWICE...thought the first one was a 'fluke'. I replaced the pick-up tube and about 2 years later, the same thing. I use only external set-ups now.
If you like drag racing, support your local track.
Re: Hemi oil P/U tube broke off ! [Re: Lee446] #1267982
07/18/12 07:43 AM
07/18/12 07:43 AM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
some of those chinese pickups have thin wall tubing and when cut with the pipe die it does not leave enough wall thickness
i had one brake off right in my hand
Re: Hemi oil P/U tube broke off ! [Re: BIGSTROKER] #1267983
07/18/12 04:00 PM
07/18/12 04:00 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
The Mopar Performance pickups are Chinese?
Re: Hemi oil P/U tube broke off ! [Re: Lee446] #1267984
07/18/12 04:15 PM
07/18/12 04:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Get away from the screw in pickups, they are very weak.
I have broke entire oil pumps off the rear main cap from tire shake.
Re: Hemi oil P/U tube broke off ! [Re: Challenger 1] #1267985
07/18/12 09:59 PM
07/18/12 09:59 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
If you go with an external system, it doesn't have to be elaborate, a fixed pick up with a single line to a Milodon oil pump cover with provisions for a remote oil filter. Simple, looks cool as heck, adds about a quart and a half of oil capacity, the pan is a breeze to take off and put on, and when you change oil theres no mess from the filter laying on its side. Just a thought.
Brian Dunnigan
Re: Hemi oil P/U tube broke off ! [Re: '72CudaRacer] #1267986
07/19/12 06:55 PM
07/19/12 06:55 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Lee...sorry to hear this! I remember who built your engine,and know he's a pretty conciencious follower of details! I've NEVER heard of this problem! I better check my Moroso pick-up closely..before putting my 440 back together! I think Raff has a good idea,for when you put a new tube on it! Best Of Luck! Randy B.
