Cooling Issue #1264257
07/08/12 04:46 PM
07/08/12 04:46 PM
Loves Park, IL
HotRodRailroader Offline OP
Loves Park, IL
I have a 1969 B body with a built 440. Has about 550 hp. Removed the thermostat and engine still wants to run at about 200f when the ampiant temp. is about 85. Water pump flows really good coolant through the radiator. Engine does have large 2.5 in primary headers. All coolant is new plus running a cooling additive. last summer car ran no hotter than 185f.
Re: Cooling Issue [Re: HotRodRailroader] #1264258
07/08/12 05:28 PM
07/08/12 05:28 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
You need the stat to let the water flow properly. It needs to stay in the rad long enough to exchange the heat. Maybe the stat went bad. I would look for a high flow stat to go back with.
I want my fair share
Re: Cooling Issue [Re: HotRodRailroader] #1264259
07/08/12 06:00 PM
07/08/12 06:00 PM
Kirkland, Washington
Pacnorthcuda Offline
...and the problem is?
Re: Cooling Issue [Re: HotRodRailroader] #1264260
07/08/12 06:00 PM
07/08/12 06:00 PM
WHEN does it now run a bit hotter? around town/stoplight to stoplight or on the highway. Do run at least a 180 stat (which is not causing the problem). Any parts/tuning changes from then to now?
Re: Cooling Issue [Re: HotRodRailroader] #1264261
07/08/12 06:25 PM
07/08/12 06:25 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
What type of fan? Are you using a fan shroud?
Re: Cooling Issue [Re: nomore65BelvJim] #1264262
07/08/12 08:48 PM
07/08/12 08:48 PM
Indiana
rapid67rt Offline
rapid67rt  Offline
Indiana
What size radiator,what kind of fan?
Re: Cooling Issue [Re: rapid67rt] #1264263
07/08/12 09:03 PM
07/08/12 09:03 PM
Rockford, IL
foz Offline
International Diplomat
foz  Offline
Rockford, IL
26" radiator with 5 blade stock type fan with factory shroud.
