Re: Cooling Issue
[Re: HotRodRailroader]
#1264258
07/08/12 05:28 PM
07/08/12 05:28 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
You need the stat to let the water flow properly. It needs to stay in the rad long enough to exchange the heat. Maybe the stat went bad. I would look for a high flow stat to go back with.
I want my fair share
Re: Cooling Issue
#1264260
07/08/12 06:00 PM
07/08/12 06:00 PM
RapidRobert
WHEN does it now run a bit hotter? around town/stoplight to stoplight or on the highway. Do run at least a 180 stat (which is not causing the problem). Any parts/tuning changes from then to now?
