NE1 know a source for custom length shifter cables? #1263514
07/07/12 04:54 PM
07/07/12 04:54 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
I'm trying to install a B&M Pro Ratchet shifter that I just bought in my '70 Dart and the supplied 5 ft cable is just too short. What I really need is a 6 foot, but the next size up offered by B&M is an 8 ft which would be way too long. Does anyone know of a source for custom length cables, or if it possible to shorten an 8 ft cable properly?
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: NE1 know a source for custom length shifter cables? [Re: MadMatt] #1263515
07/07/12 06:18 PM
07/07/12 06:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The 5-footer for the Cheetah in my '64 looked too short, but it's actually fine. Comes out the front of the shifter, through a hole in the floor, and loops around. TurboAction sells longer cables but I don't know if they work with the B&M. Hole in the floor should be close to the shifter.
Re: NE1 know a source for custom length shifter cables? [Re: topside] #1263516
07/07/12 06:41 PM
07/07/12 06:41 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
Spent several days trying to route it. Because of how the headers fit, the only viable route is forward and looped back around the mini-starter to get a straight shot at the shifter lever on the trans. I just need another foot to make it work. And the cable has to be threaded on one end and have an eyelet on the other.
Re: NE1 know a source for custom length shifter cables? [Re: MadMatt] #1263517
07/07/12 06:51 PM
07/07/12 06:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Hint 1
Boating supply store
Hint 2
morse cable
I never understood why all the cables ran FORWARD, into the narrow crowded area instead of back...
Re: NE1 know a source for custom length shifter cables? [Re: RodStRace] #1263518
07/07/12 08:25 PM
07/07/12 08:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not all cables run out the front. It depends on what shifter you buy.
Re: NE1 know a source for custom length shifter cables? [Re: MadMatt] #1263519
07/07/12 09:05 PM
07/07/12 09:05 PM
KY
jeffs67 Offline
jeffs67  Offline
KY
B&M makes a 6 foot shifter cable. Check their website. They are the race version with eyelet and threaded end.
Re: NE1 know a source for custom length shifter cables? [Re: jeffs67] #1263520
07/10/12 11:56 PM
07/10/12 11:56 PM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
They make 2 6ft. cables, part #80740 and part #80506. I spoke with B&M and they tell me the 80740 will only work with Unimatic shifters, but they couldn't really explain the difference to me. They just said it wouldn't fit. The 80506 look pretty much identical to the 5 ft. Super Duty cable I have now, except it is threaded on both ends, instead of having an eyelet on one end. I'm thinking I could make an eyelet to thread on. Anyone know any more about the differences in the cables??
Re: NE1 know a source for custom length shifter cables? [Re: MadMatt] #1263521
07/11/12 12:17 AM
07/11/12 12:17 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Will the shifter let you run the cable out the back?
- Stu Harmon
Re: NE1 know a source for custom length shifter cables? [Re: feets] #1263522
07/11/12 01:02 AM
07/11/12 01:02 AM
Nampa, ID
MadMatt Offline OP
MadMatt  Offline OP
Nampa, ID
No, no way to run it out the back without major modifications.
