Page 1 of 16 1 2 3 15 16
Hemi vs Wedge #1262518
07/06/12 02:24 AM
07/06/12 02:24 AM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Very briefly, as you are all busy people.
Yes this is "race only", but who better to ask?
I am a big Wedge guy.Always have been.440/906s,446/max wedge heads,
500 siamese w/bulldog track dawgs (yeah,I know,
452/906s 6bbl
they run hard, they run good, easy to maintain and work on.Stay in tune well.(basic street/strip cars, not full race)
I always have thought if and when I ever get to a Hemi, with a stock 426 style head,even based on that alone, I would think with all the air a Hemi head can flow ,anything less than 500 cubes would not be worth the switch from a wedge.That and alloy heads to make up for some of the weight penalty.Don't want to tie up your forum, but
how about a few pointers, so I can try to be right
in my mind on this?
Thanks, Bear
Re: Hemi vs Wedge [Re: Sixgun] #1262519
07/06/12 02:51 AM
07/06/12 02:51 AM
I'v made more HP per C.I. with a good aluminum M.W. port size wedge head than I have with a Mullins ported D4 aluminum race hemi head I like wedge motors way more then Hemiriods motors
Re: Hemi vs Wedge [Re: Sixgun] #1262520
07/06/12 09:18 AM
07/06/12 09:18 AM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Keep in mind Hemis LOVE compression and RPM. The cost between a 426
and a 500+ is minimal, you need lots of air movement to make those
heads perform.
Re: Hemi vs Wedge [Re: Dan Halen] #1262521
07/06/12 10:03 AM
07/06/12 10:03 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I am a Hemi guy, and the wedge is easier to maintain for racing. Now a days, the wedge heads flow pretty good. We have a set that flow a little over 360cfm and we are running 10.0's on pump gas with a wedge. Yeah the Hemi heads flow, but stock heads need work. The valve guides are over size, and the seats can be an issue as well. You will be better off with a set of Stage V heads and go from there.
With a Hemi, oiling is critical. If your going to build one, run the oiling on the stand and get it sorted out before it goes in the car.
Re: Hemi vs Wedge [Re: Sixgun] #1262522
07/06/12 10:06 AM
07/06/12 10:06 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
This debate will rage on forever...
They both make good power. All Ill say is this, and I drive and build a lot of brandX stuff, too. All things being equal(like dont compare a full boogie B-1 with a stock street hemi), nothing feels like a hemi up top. It turns on when the others are turning off. Period...
MB
Re: Hemi vs Wedge [Re: Sixgun] #1262523
07/06/12 11:11 AM
07/06/12 11:11 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
$ for $ a wedge is hard to beat.
Coming soon!!!!
Re: Hemi vs Wedge [Re: Mr.Yuck] #1262524
07/06/12 11:27 AM
07/06/12 11:27 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
A wedge will work but a hemi is prettier. Hemi's used to be expensive so I understand why people drove wedges but today if you are building from new parts the cost is the same nearly to the penny. (If you want to go thru the price list item by item we will.) I will never figure out why someone would drive a wedge.
2011 Drag Pak Challenger
Re: Hemi vs Wedge [Re: rickseeman] #1262525
07/06/12 11:39 AM
07/06/12 11:39 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
really? crank, rods, pistons, cam maybe but blocks, heads and valve train? no way. Hemi headers and intake are also more expensive. You'll spend 2x as much (maybe more) building a 600hp hemi vs wedge.
Re: Hemi vs Wedge [Re: HPMike] #1262526
07/06/12 11:46 AM
07/06/12 11:46 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
MB
Exactly that: I just switched tow vehicles last year and just 2 weeks ago opened up the 5.7 hemi on the highway. The old truck was a 5.9 and would start to lay over around 90-95 mph and the 5.7 started really moving about 80 and didn't quit until I did @110mph. I'd say that's an equal comparison.
Yeah, it's got a smallblock.
Re: Hemi vs Wedge [Re: 340B5] #1262527
07/06/12 01:13 PM
07/06/12 01:13 PM
Western Washington
Sixgun Offline OP
Sixgun  Offline OP
Western Washington
Cab,Mr Yuck,340B5,Mr Seeman,HPMike,Dragula,StreetVanDan,
thank you all,I am not being a pot stirrer, but this is EXACTLY what I was asking for.
I am a little clearer on the whole thing,as it would apply to ME, here and now.
I sure do appreciate first hand information/opinion.
Great day to you all,and whoever else has anything to add later.
Bear
Re: Hemi vs Wedge [Re: Sixgun] #1262528
07/06/12 02:32 PM
07/06/12 02:32 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We moved up from a small block to a big block wedge for cost reasons many years ago. Back then Hemi's were way more expensive, nowadays I'd guess it's a lot closer but the Hemi's are still more expensive.
Re: Hemi vs Wedge [Re: Tig] #1262529
07/06/12 06:47 PM
07/06/12 06:47 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Stock castings the 426 has almost unlimited horsepower, the wedge not so much, the heads just do not flow anywhere near what the Hemi's do. Wedge block is good for what, 600HP before it breaks, 426 Hemi at least double that.
So you want your wedge to make big power so you need an aftermarket block, heads, rocker gear etc. Same cost as Hemi aftermarket parts.
They're both great engines but different.
Most people have never driven a Hemi, a stock 440 car still pulls okay when you punch it in high gear, a stock 426 Hemi pulls like gangbusters in high gear and feels like that wedge does in low gear. 440 is a great torque engine, the 426 Hemi is a great horsepower engine.
Sheldon
Re: Hemi vs Wedge [Re: Tig] #1262530
07/06/12 09:36 PM
07/06/12 09:36 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Where the wedges start to nose over the Hemi will be just starting to pull hard. For you wedge guys, don't buy or build a Hemi. Once bitten by the Hemi bug you'll forget all about running a wedge. Dave
Re: Hemi vs Wedge [Re: Sixgun] #1262531
07/06/12 11:40 PM
07/06/12 11:40 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Always liked wedges for street motors.
Re: Hemi vs Wedge [Re: Twin Turbo Mower] #1262532
07/07/12 12:15 AM
07/07/12 12:15 AM
campbell river B.C
mopartoby Offline
mopartoby  Offline
campbell river B.C
Nowadays hemi is just a word. Stick with the wedge!
Re: Hemi vs Wedge [Re: Sixgun] #1262533
07/07/12 08:06 AM
07/07/12 08:06 AM
SW WI
cudacustoms1 Offline
SW WI
To me it really depends on amount of HP/cash. Lower dollar/HP weadge all the way. Hemi can't be done on the cheap. When you start ordering new everything then parts cost very close to the same.
Re: Hemi vs Wedge [Re: cudacustoms1] #1262534
07/07/12 09:30 AM
07/07/12 09:30 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Pro: That Hemi top end charge
Con: The combo to make it possible
If I were to start over again?
Re: Hemi vs Wedge [Re: Tig] #1262535
07/07/12 09:50 AM
07/07/12 09:50 AM
Indiana
Scott58 Offline
Scott58  Offline
Indiana
When we were discussing a new big cube build, this topic came up and we spent quite a bit of time discussing it. For a high-end NA street/strip engine, the performance difference between hemi and wedge is almost non-existent now with the big B1 and Predator products. Hemi is still a bit more expensive. The tie breakers for me? Resale value and "wow" factor. As somebody said, "Hemi" may just be a word, but it's a word that always draws a crowd when the hood comes off, and its worth another $5-$10K in resale value at the engine or car level when it's time to sell. Hemi's definitely hold value better than wedges.
I came across a used set of Millennium heads for a good price, so the cost difference was eliminated. I'm building a hemi!
Re: Hemi vs Wedge [Re: HPMike] #1262536
07/07/12 10:00 AM
07/07/12 10:00 AM
Mo.
racerx Offline
racerx  Offline
Mo.
MB
Hmm.r we talking about top end charge in the 1/4 mi or highway
Re: Hemi vs Wedge [Re: RUNCHARGER] #1262537
07/07/12 10:12 AM
07/07/12 10:12 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sheldon
plenty of 600+ wedges out there. Not sure why 600 hp or 6500 are peoples #'s for a wedge. I guess it all depends on the budget. You can make cheaper, more dependable 10 second wedge that a Hemi. If you want more "top end" w/ a wedge all you need to do is add a little boost. FWIW my 440-6 is still pulling hard at the stripe, it's no where close to "done"
