Indy rockers ?????? #1259186
06/29/12 11:15 AM
06/29/12 11:15 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Having a hard time keeping the rocker arms adjusted they loosen up won't stay put. Is it possible the screw and lock nut are no good?
Thanks Matt
Re: Indy rockers ?????? [Re: MattW] #1259187
06/29/12 11:55 AM
06/29/12 11:55 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Hemi or wedge?
Re: Indy rockers ?????? [Re: MattW] #1259188
06/29/12 01:24 PM
06/29/12 01:24 PM
NEW YORK
MAXEDWEDGE Offline
MAXEDWEDGE  Offline
NEW YORK
If it's a wedge with a roller cam DON'T run big spring presure (nex tek) , the'll break .run the comp cam 991?i think and you should be ok
Re: Indy rockers ?????? [Re: 64dodge572] #1259189
06/29/12 02:58 PM
06/29/12 02:58 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Smallblock flat tapped mechanical.
I adjust the valve lash and after a couple of runs have to adjust it again.
Re: Indy rockers ?????? [Re: MattW] #1259190
06/29/12 03:02 PM
06/29/12 03:02 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Has the performance of the car changed any?
Pushrod tips look good?
New or used rockers?
RIP Monte Smith
Re: Indy rockers ?????? [Re: CompWedgeEngines] #1259191
06/29/12 03:24 PM
06/29/12 03:24 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
On Dyno.
Tip are good.
New rockets.
I can't seem to get it to stay put. I don't think they are adjusted wrong. Made sure on base circle.
I think there was a previous post about indy adjusters being junk.
Re: Indy rockers ?????? [Re: MattW] #1259192
06/29/12 03:59 PM
06/29/12 03:59 PM
fresno ca
mikeysmopars Offline
fresno ca
On Dyno.
Tip are good.
New rockets.
You think Right..
Harland Sharp
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Indy rockers ?????? [Re: mikeysmopars] #1259193
06/29/12 06:24 PM
06/29/12 06:24 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
brand new, first time out, we found that the adjuster hole was drilled at one angle but the thread was installed at another. not hard to figure out why the adjuster pushed thru.
Re: Indy rockers ?????? [Re: rebel] #1259194
06/29/12 06:50 PM
06/29/12 06:50 PM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Same a rebel said. My friend had the same happend to him with one rocker. It was not drilled and tapped right and would keep coming loose. He just replaced the one rocker and has been fine.
Re: Indy rockers ?????? [Re: Twin Turbo Mower] #1259195
06/29/12 07:58 PM
06/29/12 07:58 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
So far no problems here on my small block.....
Re: Indy rockers ?????? [Re: MattW] #1259196
06/29/12 11:10 PM
06/29/12 11:10 PM
tn
robnbird Offline
robnbird  Offline
tn
Thanks Matt
I have used Indy before, and they are a good cheepy rocker arm. But I never had any problem the nut backing off. How tight are you getting the nut.
Re: Indy rockers ?????? [Re: MattW] #1259197
06/30/12 05:06 AM
06/30/12 05:06 AM
OZ
CRIKEY Offline
super gas
CRIKEY  Offline
super gas
OZ
Theres no question Indy rockers are junk for solid rollers, but flat tappet pressures should be fine. How certain are you the lobes arent going round?
Re: Indy rockers ?????? [Re: CRIKEY] #1259198
06/30/12 10:33 PM
06/30/12 10:33 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
the adjusters seem fine, i run a set of indy adjuster's in my hemi (non indy rockers). never had any issues.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Indy rockers ?????? [Re: robnbird] #1259199
07/01/12 09:50 PM
07/01/12 09:50 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Thanks Matt
From the responses it seem to me that I may not be adjusting them correctly.
Thanks for everybody's input.
Re: Indy rockers ?????? [Re: MattW] #1259200
07/02/12 10:31 AM
07/02/12 10:31 AM
Ma
Voluster Offline
Voluster  Offline
Ma
I changed the adjusters on mine before I even fired the thing
Went to adjust them and the allen head stripped out 1st one. Called summit and ordered cranes or comp whoever made them. I adjust mine twice a year and only find a couple that are out
