Re: Indy rockers ??????
[Re: MattW]
#1259190
06/29/12 03:02 PM
06/29/12 03:02 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Has the performance of the car changed any?
Pushrod tips look good?
New or used rockers?
RIP Monte Smith
[Re: CompWedgeEngines]
#1259191
06/29/12 03:24 PM
06/29/12 03:24 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
On Dyno. Tip are good. New rockets. I can't seem to get it to stay put. I don't think they are adjusted wrong. Made sure on base circle. I think there was a previous post about indy adjusters being junk.
[Re: MattW]
#1259196
06/29/12 11:10 PM
06/29/12 11:10 PM
Posts: 914 tn
robnbird
tn
Having a hard time keeping the rocker arms adjusted they loosen up won't stay put. Is it possible the screw and lock nut are no good? Thanks Matt
I have used Indy before, and they are a good cheepy rocker arm. But I never had any problem the nut backing off. How tight are you getting the nut.
[Re: CRIKEY]
#1259198
06/30/12 10:33 PM
06/30/12 10:33 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
the adjusters seem fine, i run a set of indy adjuster's in my hemi (non indy rockers). never had any issues.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: robnbird]
#1259199
07/01/12 09:50 PM
07/01/12 09:50 PM
MattW
Ontario Canada
From the responses it seem to me that I may not be adjusting them correctly. Thanks for everybody's input.
