few questions about 904 tranny in my 340 roadrunner... #1259088
06/29/12 12:55 AM
06/29/12 12:55 AM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
I have a few questions regarding a 904 in my 71 340 roadrunner. my car originally had a 727, but for a few factors, Im running a 904 instead. im pretty sure the tail shaft lengths are different between 727 and 904. would I be able to use my original drive shaft? or does it have to be lengthened? also, the tranny I got came out of a A body, IIRC, it doesn't matter like it does for 4 speeds as far as overall length goes? thanks
-kevin
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259089
06/29/12 01:06 AM
06/29/12 01:06 AM
Wisconsin
moparkid88 Offline
moparkid88  Offline
Wisconsin
As far as I know all 904s are the same length..Also I'm pretty sure the driveshaft has to be lengthened.
1973 Charger SE 1987 Ram 4x4 lifted 318 4spd 1984 Ram 4x2 mild 360 1995 Neon 2.0 w/bolt ons
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259090
06/29/12 01:29 AM
06/29/12 01:29 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
All 904 lengths are the same. If you're swapping a 904 in place of a 727, the 904 is shorter so the 727 driveshaft will be too short. AFAIK you cant lengthen the driveshaft - the tube has to be replaced. No change needed for the crossmember though.
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259091
06/29/12 01:47 AM
06/29/12 01:47 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Your 904 will need a longer driveshaft AND a smaller diameter spline-yoke.
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259092
06/29/12 02:09 AM
06/29/12 02:09 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes as said longer shaft and the different yoke , also that 904 needs to be up to the task of handling the 340 .
Re: few questions about 904 tranny in my 340 roadrunner... [Re: JohnRR] #1259093
06/29/12 02:13 PM
06/29/12 02:13 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
thanks guys for the feedback. I just remembered I have a drive shaft out of a 72 318/ 904 sattelite I guess that should go right in. the 904 isn't going to be stock
1937 Plymouth PT50
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259094
06/29/12 02:41 PM
06/29/12 02:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did that car have the same rear as your runner ?
Re: few questions about 904 tranny in my 340 roadrunner... [Re: JohnRR] #1259095
06/29/12 07:05 PM
06/29/12 07:05 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
it was an 8 1/4. I spose I spoke too soon? or were 8 1/4s similar enough?
1937 Plymouth PT50
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259096
06/29/12 09:02 PM
06/29/12 09:02 PM
Both 8&1/4's? I would mock it up with the suspension loaded & see what you do have for end play. Want 3/4"-1"
Re: few questions about 904 tranny in my 340 roadrunner... [Re: RapidRobert] #1259097
06/29/12 10:37 PM
06/29/12 10:37 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
my roadrunner has the standard 8 3/4. good to know the 3/4-1" though. thanks!
1937 Plymouth PT50
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259098
06/30/12 02:57 PM
06/30/12 02:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
8.25 driveshaft is different length than 8.75 , I'm do not know the difference in length .
edit ... a check of the tech archive says the 8.25 driveshaft will be ~.66" LONGER than the 8.75 driveshaft. up to you to determine if this is going to be a problem.
Re: few questions about 904 tranny in my 340 roadrunner... [Re: JohnRR] #1259099
07/03/12 02:06 PM
07/03/12 02:06 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
Thank you very much for looking that up for me! would .66" really matter? Im no driveshaft expert lol
1937 Plymouth PT50
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259100
07/03/12 05:14 PM
07/03/12 05:14 PM
Alabama USA
Silver6Pak Offline
Silver6Pak  Offline
Alabama USA
Any time I ever went from a 904 to a 727, I had to shorten the driveshaft. Reverse of what you are doing. Here in town there is a shop that specializes in driveshafts and such. They also stock Spicer/Dana Ujoints and do a fine job.
Re: few questions about 904 tranny in my 340 roadrunner... [Re: mopars_1] #1259101
07/03/12 05:23 PM
07/03/12 05:23 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
You need to make sure that you have at least 3/4" to 1" of travel room. Do this with the car resting on the suspension.
Re: few questions about 904 tranny in my 340 roadrunner... [Re: Reggie] #1259102
07/03/12 11:12 PM
07/03/12 11:12 PM
Ridgeland Wi
mopars_1 Offline OP
mopars_1  Offline OP
Ridgeland Wi
understood
1937 Plymouth PT50
