few questions about 904 tranny in my 340 roadrunner...
#1259088
06/29/12 12:55 AM
06/29/12 12:55 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I have a few questions regarding a 904 in my 71 340 roadrunner. my car originally had a 727, but for a few factors, Im running a 904 instead. im pretty sure the tail shaft lengths are different between 727 and 904. would I be able to use my original drive shaft? or does it have to be lengthened? also, the tranny I got came out of a A body, IIRC, it doesn't matter like it does for 4 speeds as far as overall length goes? thanks -kevin
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: few questions about 904 tranny in my 340 roadrunner...
[Re: mopars_1]
#1259089
06/29/12 01:06 AM
06/29/12 01:06 AM
Posts: 213 Wisconsin
moparkid88
Wisconsin
As far as I know all 904s are the same length..Also I'm pretty sure the driveshaft has to be lengthened.
1973 Charger SE
1987 Ram 4x4 lifted 318 4spd
1984 Ram 4x2 mild 360
1995 Neon 2.0 w/bolt ons
[Re: mopars_1]
#1259090
06/29/12 01:29 AM
06/29/12 01:29 AM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
All 904 lengths are the same. If you're swapping a 904 in place of a 727, the 904 is shorter so the 727 driveshaft will be too short. AFAIK you cant lengthen the driveshaft - the tube has to be replaced. No change needed for the crossmember though.
[Re: mopars_1]
#1259094
06/29/12 02:41 PM
06/29/12 02:41 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
thanks guys for the feedback. I just remembered I have a drive shaft out of a 72 318/ 904 sattelite I guess that should go right in. the 904 isn't going to be stock
Did that car have the same rear as your runner ?
[Re: mopars_1]
#1259096
06/29/12 09:02 PM
06/29/12 09:02 PM
RapidRobert
Both 8&1/4's? I would mock it up with the suspension loaded & see what you do have for end play. Want 3/4"-1"
[Re: mopars_1]
#1259101
07/03/12 05:23 PM
07/03/12 05:23 PM
Reggie
Bowie, MD
Thank you very much for looking that up for me! would .66" really matter? Im no driveshaft expert lol
You need to make sure that you have at least 3/4" to 1" of travel room. Do this with the car resting on the suspension.
