which wideband for open headers #1258032
06/26/12 10:44 PM
06/26/12 10:44 PM
fresno ca
mikeysmopars Offline OP
fresno ca
I want to add a wideband to my ride, Its open headers and heard they'r a little harder to work with on open headers. Which one do you suggest?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: which wideband for open headers [Re: mikeysmopars] #1258033
06/27/12 01:36 AM
06/27/12 01:36 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
All of them ,, just move the wide band around to every hole and see how you are doing . wide band bungs and plugs are cheap .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: which wideband for open headers [Re: go green] #1258034
06/27/12 05:34 AM
06/27/12 05:34 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
If you mean a gauge, i use the AEM UEGO, i run open headers with collectors.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: which wideband for open headers [Re: deaks] #1258035
06/27/12 08:48 AM
06/27/12 08:48 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
If you're monitoring in the collector, make sure the sensor is at least 12inches from the end. This usually means collector extensions. If the sensors are too close to the end they won't read correct until full load, full throttle even then I wouldn't be too sure.
HTH's
Re: which wideband for open headers [Re: mikeysmopars] #1258036
06/27/12 10:20 AM
06/27/12 10:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just looking at your headers I would say you can use
longer collectors anyways... most engines like a
collector about 16"-18" long... it'll make more torque
Re: which wideband for open headers [Re: MR_P_BODY] #1258037
06/27/12 10:59 AM
06/27/12 10:59 AM
fresno ca
fresno ca
Thanks All, Very helpfull
Re: which wideband for open headers [Re: go green] #1258038
06/27/12 11:33 AM
06/27/12 11:33 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Re: which wideband for open headers [Re: boatracer572] #1258039
06/27/12 12:50 PM
06/27/12 12:50 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As stated any of the will be fine. They will onlybe accurate at full throtle but since it is a racecar tat is all that matters.
Re: which wideband for open headers [Re: Al_Alguire] #1258040
06/27/12 05:52 PM
06/27/12 05:52 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've been looking too, my street/strip 408 needs to be fine tuned. It gets confusing to me after reading several posts. It seems what works for one don't work for other people. I want something that will record so I can look at it later and not have to worry about running over something trying to watch it .
Suggestions? Sorry for the hi jack .
Re: which wideband for open headers [Re: go green] #1258041
06/28/12 12:40 AM
06/28/12 12:40 AM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
If i were building a set of headers,they would have 10 O2 sensor bungs along with 8 egt bungs. Do it right the 1st time.
Joe
Without Data, you’re just another guy with an opinion.
Re: which wideband for open headers [Re: sr4440] #1258042
06/28/12 01:33 AM
06/28/12 01:33 AM
fresno ca
fresno ca
Do these bungs need to be spaced spacifically?
Anyone have pics?
Re: which wideband for open headers [Re: mikeysmopars] #1258043
06/28/12 08:33 AM
06/28/12 08:33 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Ideally they should go in at the 12 O'clock position. With underbody headers there's usually enough room to fit at the 10 and 2 O'clock positions. The instructions will tell you to fit the sensors pointing down as much as possible to stop water/condensation forming in the sensors as it contaminates them.
Also remember that everytime you switch the car on, the sensors will heat up. So don't leave the little plastic protectors on them when you switch the car on, they will melt. Don't ask me how I know
Re: which wideband for open headers [Re: mikeysmopars] #1258044
06/28/12 10:30 AM
06/28/12 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Anyone have pics?
I use 8 EGT to balance the intake.. and the O2s in
the collector... if you get the EGTs balanced you
wont need the 8 O2s... JMO... plus most headers are
hard to get the big O2 bungs in there.... all of my
EGTs are always exactly 1"(I use a set of calipers to
set the probe distance) from the header flange... that
way your trying to get equal reading
Re: which wideband for open headers [Re: MR_P_BODY] #1258045
06/28/12 07:34 PM
06/28/12 07:34 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i use a wego3. it has a live readout and is the size of a credit card.
will record from .1sec to i think 2sec. 800 samples do the math
logs rpm and o2 and a third 0 to 5vdc input. small simple works.
Re: which wideband for open headers [Re: justinp61] #1258046
06/29/12 07:35 AM
06/29/12 07:35 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
You could video it with one of those cheap, action camera things from ebay, they seem to work OK. Once you've got a handle on the ratio's you can use it for other fun stuff too
Re: which wideband for open headers [Re: Tig] #1258047
06/29/12 11:06 AM
06/29/12 11:06 AM
fresno ca
fresno ca
Don't let your buddies get a hold of it though, They will show you and everyone else what you do wrong going down the track...Don't ask me how i know
Re: which wideband for open headers [Re: mikeysmopars] #1258048
06/29/12 11:36 AM
06/29/12 11:36 AM
Bakersfield Ca
jmoparman Offline
jmoparman  Offline
Bakersfield Ca
It's a learning tool, Did It work?
Re: which wideband for open headers [Re: jmoparman] #1258049
06/29/12 12:16 PM
06/29/12 12:16 PM
fresno ca
fresno ca
Ya it worked.... I dont let no one near my car anymore.
Re: which wideband for open headers [Re: mikeysmopars] #1258050
06/30/12 02:43 PM
06/30/12 02:43 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
