which wideband for open headers
#1258032
06/26/12 10:44 PM
06/26/12 10:44 PM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I want to add a wideband to my ride, Its open headers and heard they'r a little harder to work with on open headers. Which one do you suggest?
Founder and CEO of the Central Valley Mopar Drag Pack
Re: which wideband for open headers
[Re: go green]
#1258034
06/27/12 05:34 AM
06/27/12 05:34 AM
Posts: 3,210 robin hood country
deaks
robin hood country
If you mean a gauge, i use the AEM UEGO, i run open headers with collectors.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#1258035
06/27/12 08:48 AM
06/27/12 08:48 AM
Posts: 2,929 A shed in England
Tig
A shed in England
If you're monitoring in the collector, make sure the sensor is at least 12inches from the end. This usually means collector extensions. If the sensors are too close to the end they won't read correct until full load, full throttle even then I wouldn't be too sure. HTH's
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: mikeysmopars]
#1258036
06/27/12 10:20 AM
06/27/12 10:20 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Just looking at your headers I would say you can use longer collectors anyways... most engines like a collector about 16"-18" long... it'll make more torque
[Re: boatracer572]
#1258039
06/27/12 12:50 PM
06/27/12 12:50 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
As stated any of the will be fine. They will onlybe accurate at full throtle but since it is a racecar tat is all that matters.
[Re: Al_Alguire]
#1258040
06/27/12 05:52 PM
06/27/12 05:52 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I've been looking too, my street/strip 408 needs to be fine tuned. It gets confusing to me after reading several posts. It seems what works for one don't work for other people. I want something that will record so I can look at it later and not have to worry about running over something trying to watch it . Suggestions? Sorry for the hi jack .
[Re: sr4440]
#1258042
06/28/12 01:33 AM
06/28/12 01:33 AM
mikeysmopars
fresno ca
Do these bungs need to be spaced spacifically? Anyone have pics?
[Re: mikeysmopars]
#1258043
06/28/12 08:33 AM
06/28/12 08:33 AM
Tig
A shed in England
Ideally they should go in at the 12 O'clock position. With underbody headers there's usually enough room to fit at the 10 and 2 O'clock positions. The instructions will tell you to fit the sensors pointing down as much as possible to stop water/condensation forming in the sensors as it contaminates them. Also remember that everytime you switch the car on, the sensors will heat up. So don't leave the little plastic protectors on them when you switch the car on, they will melt. Don't ask me how I know
[Re: mikeysmopars]
#1258044
06/28/12 10:30 AM
06/28/12 10:30 AM
MR_P_BODY
I use 8 EGT to balance the intake.. and the O2s in the collector... if you get the EGTs balanced you wont need the 8 O2s... JMO... plus most headers are hard to get the big O2 bungs in there.... all of my EGTs are always exactly 1"(I use a set of calipers to set the probe distance) from the header flange... that way your trying to get equal reading
[Re: MR_P_BODY]
#1258045
06/28/12 07:34 PM
06/28/12 07:34 PM
Posts: 319 jonestown,pa
dmking
jonestown,pa
i use a wego3. it has a live readout and is the size of a credit card. will record from .1sec to i think 2sec. 800 samples do the math logs rpm and o2 and a third 0 to 5vdc input. small simple works.
[Re: justinp61]
#1258046
06/29/12 07:35 AM
06/29/12 07:35 AM
Tig
A shed in England
You could video it with one of those cheap, action camera things from ebay, they seem to work OK. Once you've got a handle on the ratio's you can use it for other fun stuff too
