Alcohol users Top Lube or Not!!!! #1256071
06/23/12 04:01 PM
06/23/12 04:01 PM
Sweet Home Alabama
MRMOPAR622 Offline OP
Sweet Home Alabama
The ones of you that are running alcohol are have knowledge on running alcohol,do you use Top Lube or not?
I have always used it thinking I needed it to lubricate the top end of the engine. I went to the Racing Zone a few mins. ago to pick up a couple of bottles,and a few more big time racers where there buying a couple of drums of alcohol and said never run it because it will clog up your fuel system.
I stop running the smell good in it last year,you don't have near as many people milling around the car.
Not sure if I should stop running the Top Lube!
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Alocohol users Top Lube or Not!!!! [Re: MRMOPAR622] #1256072
06/23/12 04:23 PM
06/23/12 04:23 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I use top lube w/ my SV-1 when using regular methanol. VP M-3 & M-5 dont need it. Those who use an EFI w/methanol dont use it because in can clog it up.If your looking for more methanol info search "methanol" here, dragraceresults.com or yellowbullet.com.
Re: Alocohol users Top Lube or Not!!!! [Re: DavidDean] #1256073
06/23/12 04:59 PM
06/23/12 04:59 PM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
We used M1 in our 640ci engine and always used top lube. If you are using mechanical injection I would recommend it. I can't see what it will clog. Corrosion in your lines will clog something before the additive will IMO.
Re: Alocohol users Top Lube or Not!!!! [Re: MRMOPAR622] #1256074
06/23/12 06:48 PM
06/23/12 06:48 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
I dont run it. Had problems with accelerator check needles and float needles sticking.
Re: Alocohol users Top Lube or Not!!!! [Re: eds dart] #1256075
06/23/12 11:18 PM
06/23/12 11:18 PM
NW Minnesota
Maximus_Wedges Offline
NW Minnesota
We use Klotz Top lube. Most of the roundy round Alky burners are using it up here. One qt. per 55 gal drum works great for us. We never drain between races. Jessie at Big's was really impresed on how nice our carb looked inside after 5 years of racing.
Re: Alocohol users Top Lube or Not!!!! [Re: Maximus_Wedges] #1256076
06/24/12 12:06 AM
06/24/12 12:06 AM
PA
moparacer Offline
moparacer  Offline
PA
I run injection and have never run lube.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Alocohol users Top Lube or Not!!!! [Re: moparacer] #1256077
06/24/12 08:32 AM
06/24/12 08:32 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I had some issues with Power plus a few years ago. Clogged injector screens and burned 2 pistons but it was just as much my fault as it was the lube due to lack of maintenance. Car sat 7 months and I moved 1500 miles and never cleaned the system before running it.
Also had some trouble with Redline, seems it was falling out of suspension. I ended up with a gooey puddle of lube on my intake plenum and at hard acceleration it would actually foul a couple of spark plugs momentarily.
I have been using Klotz Uplon for 5 years now, 1/2qt per 55gal drum and my carb/fuel system has been perfect.
Re: Alocohol users Top Lube or Not!!!! [Re: MegaDart] #1256078
06/24/12 09:12 AM
06/24/12 09:12 AM
gregsdart Offline
gregsdart  Offline
Klotz Uplon here. Very little maintenance, just check filters once in a while.
Re: Alocohol users Top Lube or Not!!!! [Re: gregsdart] #1256079
06/24/12 09:50 AM
06/24/12 09:50 AM
Tennessee
steeldust Offline
steeldust  Offline
Tennessee
I run Top lube and i have no filter on my car and i have had no trouble with my carb or my fuel
Re: Alocohol users Top Lube or Not!!!! [Re: Maximus_Wedges] #1256080
06/24/12 11:04 AM
06/24/12 11:04 AM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Same here but it is one of those things that too much is not a good thing.
Re: Alocohol users Top Lube or Not!!!! [Re: mac56] #1256081
06/25/12 05:33 PM
06/25/12 05:33 PM
Sweet Home Alabama
Sweet Home Alabama
Thanks for the all the advice
Just wanted to make sure I was not doing anything wrong.
I run Terminators(mechanical injection)so I think I will stay with the top lube,may start using the Klotz!
Re: Alocohol users Top Lube or Not!!!! [Re: MRMOPAR622] #1256082
06/25/12 06:11 PM
06/25/12 06:11 PM
oh
julian2007 Offline
julian2007  Offline
oh
Been using power plus for 4 years no no problems.I used some left over fuel from last year to start the season no problems.All I do is drain the carb and fill with wd-40 if its going to sit for a while.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Alocohol users Top Lube or Not!!!! [Re: julian2007] #1256083
06/26/12 01:42 AM
06/26/12 01:42 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
Cant see the point other than monkey see monkey do. I do not use it .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Alocohol users Top Lube or Not!!!! [Re: go green] #1256084
06/26/12 05:20 PM
06/26/12 05:20 PM
gregsdart Offline
gregsdart  Offline
Uplon leaves a coating as it evaporates on my stuff. Keeps corrosion at bay and I haven't hung a valve like some who don't run any lube. Same pump and system thirteen years. No corrosion anywhere, never drain it or top it off. Just park it.
