The ones of you that are running alcohol are have knowledge on running alcohol,do you use Top Lube or not?
I have always used it thinking I needed it to lubricate the top end of the engine. I went to the Racing Zone a few mins. ago to pick up a couple of bottles,and a few more big time racers where there buying a couple of drums of alcohol and said never run it because it will clog up your fuel system.
I stop running the smell good in it last year,you don't have near as many people milling around the car.
Not sure if I should stop running the Top Lube!
