Aeroheadracing Heads. Any Past Experiences Good or Bad?
#1254992
06/21/12 01:33 PM
06/21/12 01:33 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
I'm thinking of buying a set of recon 906 heads for my 69 Super Bee. Looking for feed back from previous experiences with them.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad?
[Re: burdar]
#1254994
06/21/12 02:56 PM
06/21/12 02:56 PM
Posts: 1,973 SoCal
jake4cars
SoCal
[Re: TimS]
#1254996
06/21/12 06:07 PM
06/21/12 06:07 PM
RapidRobert
I understand that Aerohead is Indy's assembly line econo version. We bought a set years ago & no problems but from what I've read I'm in the minority
[Re: dogdays]
#1254998
06/21/12 08:58 PM
06/21/12 08:58 PM
TimS
Walton, Indiana
Thanks for the input. I've got a used set of 906 heads that have been sitting around awhile and need to be checked. May be worth while to just put some money in these. I found out by accident that my #'s 69 Bee has had 516 heads put on it sometime in its life and I want to go back to correct. I've got leaky valves on the left side anyhow so now is the time to fix it and maybe even stick a new cam in.
[Re: TimS]
#1254999
06/21/12 11:52 PM
06/21/12 11:52 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
They're absolute junk. Years ago, I bought a pair of 2.02" 587s from them. They machined for the 2.02" seats, but .125" down, it immediately necked down to the stock 1.88" valve size. Absolute garbage. Took a lot to clean them up into something worth using.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: TimS]
#1255000
06/22/12 07:26 AM
06/22/12 07:26 AM
TimS
Walton, Indiana
Glad I got some input before investing in a set of these. I was prepared to head down on Monday and pick up a set of 906's. Like to find a ready to bolt on set I can trust but just haven't run across any.
[Re: TimS]
#1255001
06/22/12 08:36 AM
06/22/12 08:36 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
We put a set on my kids built 360 about 15 years ago.Changed the springs to match the cam and my machinist checked them.No problems at all.They havent benn run a lot but we had no problems.Rocky
Chrysler Firepower
[Re: TimS]
#1255006
06/23/12 10:12 PM
06/23/12 10:12 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Thanks.
What do you want? We can do them from stock to over 330 cfm. The best test we ever recorded was 349 cfm.
Jim LaRoy LaRoy Engines Challis, ID
[Re: TimS]
#1255008
06/24/12 08:41 PM
06/24/12 08:41 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
I'm surprised considering Indy Cylinder Heads reputation, of which I always thought was good.
You've obviously never paid any attention to the threads of Indy then ...
[Re: TimS]
#1255009
06/24/12 08:44 PM
06/24/12 08:44 PM
JohnRR
U.S.S.A.
Sure you have , what's your definition of TRUST ... ????
[Re: LaRoy Engines]
#1255010
06/24/12 08:52 PM
06/24/12 08:52 PM
JohnRR
U.S.S.A.
Thanks.
A head that flows that high at .800 lift is useless with a .450 lift cam .
[Re: JohnRR]
#1255011
06/24/12 09:57 PM
06/24/12 09:57 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Thanks.
Have I been chastised?
So how about a little more than stock? Because, I don't recall suggesting 340 cfm, but was offering alternatives from stock to 330+. Question, is it "useless"? Or unneccessary?
It wouldn't make any sense to pay for a head that flows at .800" lift if you are lifting to .450".
But what can a head that will flow 340 cfm @ .700-.800", be made to flow at .400"-.500"?
