Aeroheadracing Heads. Any Past Experiences Good or Bad? #1254992
06/21/12 01:33 PM
06/21/12 01:33 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I'm thinking of buying a set of recon 906 heads for my 69 Super Bee. Looking for feed back from previous experiences with them.
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1254993
06/21/12 01:41 PM
06/21/12 01:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I bought a set of 318 heads 7 or 8 years ago and just got around to using them. One head seems OK. The other has major problems.
On one head, they fixed some damage on a rocker stand and welded the oil feed hole shut. They forgot to redrill it. After getting that issue fixed, and starting the engine, I only had compression on two of the four cylinders. The exhaust valves are leaking.
I'd make sure to have a machine shop look over the heads if you decide to get them.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: burdar] #1254994
06/21/12 02:56 PM
06/21/12 02:56 PM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Run Forrest Run!!!
Joey
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1254995
06/21/12 06:01 PM
06/21/12 06:01 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I'm surprised considering Indy Cylinder Heads reputation, of which I always thought was good.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1254996
06/21/12 06:07 PM
06/21/12 06:07 PM
I understand that Aerohead is Indy's assembly line econo version. We bought a set years ago & no problems but from what I've read I'm in the minority
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: RapidRobert] #1254997
06/21/12 07:53 PM
06/21/12 07:53 PM
dogdays Offline
dogdays  Offline
Look for a parallel thread entitled "place to buy 318 heads".
Here is what a sage (me) said about Aerohead:
"The deal with "Aerohead" is that it is a part of Indy Cylinder Head. Now, that sounds really nice, everyone knows ICH. One begins having visions of low time slips.......
But search for board member input and you'll see that ICH doesn't do customer service. See that ICH sends new parts out the door that need to be fixed or scrapped. If you are going to buy any ICH product go through one of their dealers, the dealer can most of the time take care of you. But on a set of cast iron heads I'd say nonononono!"
This discussion hasn't changed in a long time. Indy makes a very nice head in theory but in reality they have been known for at least the last 15 years to have quality control issues. As Bill Clinton used to say, "It's a cryin' shame!"
Just do a search for Indy on this board, see for yourself. Don't forget to go to the race engine section.
R.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: dogdays] #1254998
06/21/12 08:58 PM
06/21/12 08:58 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks for the input. I've got a used set of 906 heads that have been sitting around awhile and need to be checked. May be worth while to just put some money in these. I found out by accident that my #'s 69 Bee has had 516 heads put on it sometime in its life and I want to go back to correct. I've got leaky valves on the left side anyhow so now is the time to fix it and maybe even stick a new cam in.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1254999
06/21/12 11:52 PM
06/21/12 11:52 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
They're absolute junk. Years ago, I bought a pair of 2.02" 587s from them. They machined for the 2.02" seats, but .125" down, it immediately necked down to the stock 1.88" valve size. Absolute garbage. Took a lot to clean them up into something worth using.
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255000
06/22/12 07:26 AM
06/22/12 07:26 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Glad I got some input before investing in a set of these. I was prepared to head down on Monday and pick up a set of 906's. Like to find a ready to bolt on set I can trust but just haven't run across any.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255001
06/22/12 08:36 AM
06/22/12 08:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We put a set on my kids built 360 about 15 years ago.Changed the springs to match the cam and my machinist checked them.No problems at all.They havent benn run a lot but we had no problems.Rocky
Chrysler Firepower
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255002
06/22/12 09:58 AM
06/22/12 09:58 AM
IL
71383beep Offline
71383beep  Offline
IL
Just an FYI the 516's are closed chambers vs the open chamber 906's and without any additional work on the heads or block it might actually drop in performance if you just swap out the heads. I had to actually pull my 906's and install built 516's to gain compression on my 383...just my
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: 71383beep] #1255003
06/22/12 04:42 PM
06/22/12 04:42 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
My 69 Bee's 383HP is the original motor so it should have the 906's. That's the reason I was just going to do a swap for the correct heads.
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255004
06/23/12 04:52 AM
06/23/12 04:52 AM
Central Ohio
rtidd440 Offline
super street
rtidd440  Offline
super street
Central Ohio
Friend of mine went with Compuflow. Had nothing but great things to say about the service.
Rob 70 Swinger 340 4spd FC7 4 sale 69 Charger auto Q5 14 Challenger SRT8 Core 6spd black Deposit on Hellcat
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: rtidd440] #1255005
06/23/12 05:18 PM
06/23/12 05:18 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
They have a web site? Where are they located?
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255006
06/23/12 10:12 PM
06/23/12 10:12 PM
Idaho
LaRoy Engines Offline
Idaho
Thanks.
What do you want? We can do them from stock to over 330 cfm. The best test we ever recorded was 349 cfm.
Jim LaRoy
LaRoy Engines
Challis, ID
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: LaRoy Engines] #1255007
06/24/12 09:10 AM
06/24/12 09:10 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Thanks.
Stock
Jim LaRoy
LaRoy Engines
Challis, ID
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255008
06/24/12 08:41 PM
06/24/12 08:41 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You've obviously never paid any attention to the threads of Indy then ...
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: TimS] #1255009
06/24/12 08:44 PM
06/24/12 08:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sure you have , what's your definition of TRUST ... ????
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: LaRoy Engines] #1255010
06/24/12 08:52 PM
06/24/12 08:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks.
Jim LaRoy
LaRoy Engines
Challis, ID
A head that flows that high at .800 lift is useless with a .450 lift cam .
Re: Aeroheadracing Heads. Any Past Experiences Good or Bad? [Re: JohnRR] #1255011
06/24/12 09:57 PM
06/24/12 09:57 PM
Idaho
Idaho
Thanks.
Jim LaRoy
LaRoy Engines
Challis, ID
Have I been chastised?
So how about a little more than stock? Because, I don't recall suggesting 340 cfm, but was offering alternatives from stock to 330+.
Question, is it "useless"? Or unneccessary?
It wouldn't make any sense to pay for a head that flows at .800" lift if you are lifting to .450".
But what can a head that will flow 340 cfm @ .700-.800", be made to flow at .400"-.500"?
