Anyone have pictures of SB Jesel belt drive? #1249910
06/12/12 05:32 PM
06/12/12 05:32 PM
AndyF Offline OP
AndyF  Offline OP
I haven't seen very many pictures of SB Mopar engines with the Jesel belt drive installed. I've seen a few Weber equipped small blocks though.
Anyone have a picture of a Jesel belt drive installed on their small block? I was mostly interested in how the water pump mounted.
The Jesel catalog doesn't show any installed pictures and it doesn't list out which water pumps work with their belt drive.
Re: Anyone have pictures of SB Jesel belt drive? [Re: AndyF] #1249911
06/12/12 06:59 PM
06/12/12 06:59 PM
Out West
408strokerdart Offline
Out West
I can answer this. They don't offer anything to hook up a water pump. They don't even give you specific instructions for the kit they sold you for $1,400+. I designed my own and they will be finished soon. Maybe this is whay they don't sell many of these kits.
I will have pics soon as I am putting everything together right now.
Re: Anyone have pictures of SB Jesel belt drive? [Re: 408strokerdart] #1249912
06/12/12 07:45 PM
06/12/12 07:45 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
By your statement you mean you are designing a water pump assembly for the belt drive or the belt drive WITH a water pump assembly?
Re: Anyone have pictures of SB Jesel belt drive? [Re: MattW] #1249913
06/12/12 08:08 PM
06/12/12 08:08 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Water pump spacers, there was a pic in the motor plate thread.
Dave Weber at least designed a pair of water pump spacers etc to go with his belt drive. The big problem is the number of belt drives for a small block Mopar that Jesel sell, I imagine they don't see designing anything else as being viable. Unless I was doing it for my own engine, I don't think I would bother myself. It would be stock I would be sitting on for a considerable amount of time.
Alan Jones
Re: Anyone have pictures of SB Jesel belt drive? [Re: LA360] #1249914
06/12/12 09:15 PM
06/12/12 09:15 PM
StewartP Offline
Mopar Vintage Picture Guy
StewartP  Offline
Jesel 1
Re: Anyone have pictures of SB Jesel belt drive? [Re: StewartP] #1249915
06/12/12 09:15 PM
06/12/12 09:15 PM
StewartP Offline
StewartP  Offline
Jesel 2
Re: Anyone have pictures of SB Jesel belt drive? [Re: StewartP] #1249916
06/12/12 10:41 PM
06/12/12 10:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Stewart, do know who sells the surrounding plate and pointer?
Re: Anyone have pictures of SB Jesel belt drive? [Re: 340Cuda] #1249917
06/12/12 10:58 PM
06/12/12 10:58 PM
StewartP Offline
StewartP  Offline
If anyone wants info on the Jesel setup, PM me
StewartP
Re: Anyone have pictures of SB Jesel belt drive? [Re: MattW] #1249918
06/13/12 12:50 AM
06/13/12 12:50 AM
Out West
Out West
My prototype spacers will be blank (as for the water pump) since I use a radiator mounted pump. I am changing the parts to accept a front mounted water pump though.
Re: Anyone have pictures of SB Jesel belt drive? [Re: StewartP] #1249919
06/13/12 01:05 AM
06/13/12 01:05 AM
Out West
Out West
Jesel 2
Stewart,
That plate setup looks nice and well thought out. How would you adapt this setup to a motor plate that is installed into a vehicle that used a stock timing cover previously? Looks like the plate stacked on top of the Jesel cover won't get you 2.5".
Re: Anyone have pictures of SB Jesel belt drive? [Re: 408strokerdart] #1249920
06/21/12 02:20 PM
06/21/12 02:20 PM
AndyF Offline OP
AndyF  Offline OP
As far as I can tell, an electric water pump bolts directly to the Jesel belt drive.
Are you trying to use a belt driven water pump with a Jesel belt drive?
Re: Anyone have pictures of SB Jesel belt drive? [Re: AndyF] #1249921
06/21/12 03:31 PM
06/21/12 03:31 PM
Out West
Out West
You are correct about being able to bolt a pump directly to the belt drive cover on a tall deck block. The problem is on a short deck block as the bolt just above the water inlet hole is not in the correct location to direct mount a pump. It is slightly lower so it fits into the block without breaking thru the deck surface. This is why everyone has to have adapters to put a pump on the short deck engines. Another issue occurs when the factory timing cover thickness is 2.50" and the Jesel cover is ~.82" and you need to make provisions for a motor plate that has frame tabs in the old location (factory timing cover). Most people going to a belt drive were probably not set up for one originally.
I was on vacation last week and have just now picked back up where I left off.
Lots of different configurations are possible and that doesn't help the problem and is probably a big reason that nobody makes these in any "standard" configuration as it won't be profitable.
Re: Anyone have pictures of SB Jesel belt drive? [Re: 408strokerdart] #1249922
06/21/12 03:49 PM
06/21/12 03:49 PM
AndyF Offline OP
AndyF  Offline OP
Jesel makes a cover for the standard 318-340-360 block so a stock type water pump will mount up directly.
If you're using a low deck block then it is tougher. I don't know if anyone is making a low deck electric water pump or not. I'm sure it could be tooled up, just not sure if anyone has done it.
I'd think most bracket race guys would be running a tall block. Either a stock LA block or a Mopar replacement block.
I can see the issue if the tabs on the frame were in the wrong location. I think it might be easier to move the tabs than to create spacers or adapters on the Jesel cover but I suppose one could go either way.
Re: Anyone have pictures of SB Jesel belt drive? [Re: 340Cuda] #1249923
06/21/12 03:54 PM
06/21/12 03:54 PM
AndyF Offline OP
AndyF  Offline OP
That looks to me to be a standard Jesel part number. CVR-32845. I don't think it is a surrounding plate, it is just one large machined block that Jesel builds for certain applications. As far as I know, you can call up Jesel and order that cover. It is listed in the catalog and has a price.
Re: Anyone have pictures of SB Jesel belt drive? [Re: AndyF] #1249924
06/21/12 09:47 PM
06/21/12 09:47 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
A keeper thanks
Re: Anyone have pictures of SB Jesel belt drive? [Re: 408strokerdart] #1249925
06/21/12 10:41 PM
06/21/12 10:41 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Brian, we just machined away what we didn't need of the high dollar MP low deck timing cover for use with the Weber belt drive.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Anyone have pictures of SB Jesel belt drive? [Re: Plumb Wired] #1249926
06/22/12 12:05 AM
06/22/12 12:05 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I found another solution so I did not follow up but this is a "R3" housing that Meziere has.
They said the measurements:
Left side C to C = 1.754
Right side C to C = 1.748 (probably both 1.75)
Lower holes C to C = 7.965
Upper holes C to C = 6.771
Bill
Re: Anyone have pictures of SB Jesel belt drive? [Re: 340Cuda] #1249927
06/23/12 10:12 AM
06/23/12 10:12 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
Do you have part # for this thanks Brett
Bill
Re: Anyone have pictures of SB Jesel belt drive? [Re: W5DART66] #1249928
06/23/12 10:57 AM
06/23/12 10:57 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Bill
Sorry I don't they just sent the info I posted to me in an email. He (Don Meziere) said he did not know if it was for an R3 or R4 block. I have not seen it on their website.
I would just send them the photo and the specs and I bet that would be enough.
Bill
Re: Anyone have pictures of SB Jesel belt drive? [Re: 340Cuda] #1249929
06/23/12 12:35 PM
06/23/12 12:35 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
just checked bolt spacing it must be for R4 as R3 and stock bolt pattern do not match the spacing you gave. thanks Brett
