what is the best w 8 head to buy #1249668
06/12/12 01:11 AM
06/12/12 01:11 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
im going to buy a set of used w8 head.for my 440 sb. what sould i be looking for looking to go mid to low 9's at 3000lb. racing at 0 to 3500 ft .. will appreciate all imput.. im done with this indy leaking junk..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: what is the best w 8 head to buy [Re: WHITEDART] #1249669
06/12/12 01:40 AM
06/12/12 01:40 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I wouldn't imagine that there is a hell of alot of them out there anymore, but from a reliability stand point I would look at an old Craftsman Truck head. They will have more meat in them than say something off a Pro Stock Truck engine. Ideally you don't want something used up or that has had to be repaired. I had a complete CFE w8 top end that I wish I never sold! Be prepared to put your hand in your wallet, nothing for them is cheap! A W9 head could be another option for you.
Alan Jones
Re: what is the best w 8 head to buy [Re: WHITEDART] #1249670
06/12/12 07:06 AM
06/12/12 07:06 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
if i were you and the goal was low 9's do w9's tons of em out there,that goal should be pretty easy w w9's
Re: what is the best w 8 head to buy [Re: fishy340] #1249671
06/12/12 08:58 AM
06/12/12 08:58 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
A raw Zeus casting (without spark plug hole) is a good foundation for the CFE treatment......
Just like the ones I have under my bed.
Re: what is the best w 8 head to buy [Re: LA360] #1249672
06/12/12 08:54 PM
06/12/12 08:54 PM
bean town ....Ca
W
W
bean town ....Ca
what valve size and stem size should i be looking for this is all new to me. thanks
Re: what is the best w 8 head to buy [Re: jim sciortino] #1249673
06/13/12 07:15 AM
06/13/12 07:15 AM
Finland
mafo Offline
mafo  Offline
Finland
are you sure they still are under your bed?
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: what is the best w 8 head to buy [Re: mafo] #1249674
06/13/12 08:44 AM
06/13/12 08:44 AM
Trumbull,CT.
Trumbull,CT.
DOH!!!!!
Re: what is the best w 8 head to buy [Re: jim sciortino] #1249675
06/13/12 08:50 AM
06/13/12 08:50 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Mid nines is nothing for W7 W8 W9 or the old Arrignton heads.
Just make sure you get something meant to run on 48 degree blocks. There are some W9 heads that are built for 59 degree lifters and I would not advise spending money going that route. Mid 9's are obtainable with Indy heads.
I highly recommend CFE W8 stuff for anyone wanting to go fast the truck stuff is just not in the same game. But, if mid 9's is all you want I would save a considerable amount of money and go with old truck stuff.
Leon
Re: what is the best w 8 head to buy [Re: WHITEDART] #1249676
06/13/12 08:52 AM
06/13/12 08:52 AM
Trumbull,CT.
Trumbull,CT.
The heads are raw. Call Foltz (CFE), tell them your plans for the engine (N/A, nitrous, etc.) and they'll fill you in.
Re: what is the best w 8 head to buy [Re: jim sciortino] #1249677
06/13/12 09:37 AM
06/13/12 09:37 AM
Finland
mafo Offline
mafo  Offline
Finland
I would consider a R5/P7 , easily goes mid nines and probably cost less
than a pair of CFE heads
Adapters are available to make it a fairly easy swap
Re: what is the best w 8 head to buy [Re: mafo] #1249678
06/13/12 01:42 PM
06/13/12 01:42 PM
utica ny
meus31 Offline
meus31  Offline
utica ny
w9 would do what your asking witrh no problem
Re: what is the best w 8 head to buy [Re: meus31] #1249679
06/13/12 05:04 PM
06/13/12 05:04 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
W-5 heads will get you mid 9's no problem. I have a complete W-5 top end from sheetmetal tunnel ram intake to head studs for sale that went 9.50s all day long at 3250lbs and 372 inches...
Re: what is the best w 8 head to buy [Re: WHITEDART] #1249680
06/13/12 05:06 PM
06/13/12 05:06 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
THE W8'S i have in my basement untouched
Re: what is the best w 8 head to buy [Re: Leon441] #1249681
06/13/12 07:54 PM
06/13/12 07:54 PM
bean town ....Ca
W
W
bean town ....Ca
the block i am going to use is a 48 degree block . what is the diffrents beteen the cup truck and pro stock truck and a compeliminator w8.
Re: what is the best w 8 head to buy [Re: stevet340] #1249682
06/13/12 08:00 PM
06/13/12 08:00 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
W-5 heads will get you mid 9's no problem. I have a complete W-5 top end from sheetmetal tunnel ram intake to head studs for sale that went 9.50s all day long at 32050lbs and 372 inches...
man thats impressive at that weight!
Mopar Performance
Re: what is the best w 8 head to buy [Re: moparniac] #1249683
06/13/12 08:36 PM
06/13/12 08:36 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I thought I read somewhere that the only difference between W8 and w9s are that the W9s are lighter? If this is not true then what is the difference?
Re: what is the best w 8 head to buy [Re: WHITEDART] #1249684
06/13/12 09:08 PM
06/13/12 09:08 PM
LA360 Offline
LA360  Offline
The Port shape/cross section and the valve sizes. The CFE stuff will typically run a 1.5-1.55" exhaust valve with a 2.18-2.25" intake valve. They will generally run a 5/16" or smaller valve stem also. The port will have a min cross section up around 3" and flow north of 400 cfm depending on the engine they were designed around.
The truck stuff runs a 2.18"/1.6" or so sized valve with a 11/32" stem valve.
The valve angle is the other change, I think the cup stuff is 15 degrees, the Pro Stock Truck was around 13 degrees, the Comp Stuff could be anywhere from 15 to 9-10 degrees.
Someone please correct me if I am mistaken, I am relying on my horrible memory here.
Alan Jones
Re: what is the best w 8 head to buy [Re: LA360] #1249685
06/13/12 10:11 PM
06/13/12 10:11 PM
bean town ....Ca
W
W
bean town ....Ca
nice
