Re: what is the best w 8 head to buy
[Re: WHITEDART]
#1249669
06/12/12 01:40 AM
06/12/12 01:40 AM
Posts: 6,186 Melbourne , Australia
LA360
I wouldn't imagine that there is a hell of alot of them out there anymore, but from a reliability stand point I would look at an old Craftsman Truck head. They will have more meat in them than say something off a Pro Stock Truck engine. Ideally you don't want something used up or that has had to be repaired. I had a complete CFE w8 top end that I wish I never sold! Be prepared to put your hand in your wallet, nothing for them is cheap! A W9 head could be another option for you.
Alan Jones
[Re: LA360]
#1249672
06/12/12 08:54 PM
06/12/12 08:54 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
what valve size and stem size should i be looking for this is all new to me. thanks
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: mafo]
#1249674
06/13/12 08:44 AM
06/13/12 08:44 AM
Posts: 2,029 Trumbull,CT.
jim sciortino
Trumbull,CT.
are you sure they still are under your bed?
DOH!!!!!
[Re: jim sciortino]
#1249675
06/13/12 08:50 AM
06/13/12 08:50 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Mid nines is nothing for W7 W8 W9 or the old Arrignton heads.
Just make sure you get something meant to run on 48 degree blocks. There are some W9 heads that are built for 59 degree lifters and I would not advise spending money going that route. Mid 9's are obtainable with Indy heads.
I highly recommend CFE W8 stuff for anyone wanting to go fast the truck stuff is just not in the same game. But, if mid 9's is all you want I would save a considerable amount of money and go with old truck stuff.
Leon
[Re: WHITEDART]
#1249676
06/13/12 08:52 AM
06/13/12 08:52 AM
jim sciortino
Trumbull,CT.
The heads are raw. Call Foltz (CFE), tell them your plans for the engine (N/A, nitrous, etc.) and they'll fill you in.
[Re: jim sciortino]
#1249677
06/13/12 09:37 AM
06/13/12 09:37 AM
Posts: 1,019 Finland
mafo
Finland
I would consider a R5/P7 , easily goes mid nines and probably cost less than a pair of CFE heads Adapters are available to make it a fairly easy swap
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Leon441]
#1249681
06/13/12 07:54 PM
06/13/12 07:54 PM
WHITEDART
bean town ....Ca
the block i am going to use is a 48 degree block . what is the diffrents beteen the cup truck and pro stock truck and a compeliminator w8.
