upper control arm cam bolts #1232972
05/13/12 10:24 PM
05/13/12 10:24 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
dumb question does anybody have pictures of how your cam bolt washers on your upper control arms are facing (in-out) front and rear and left side versus right side
thanks Charlie
Re: upper control arm cam bolts [Re: MOPARCHAS] #1232973
05/13/12 11:53 PM
05/13/12 11:53 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
are you referring to the eccentric position or where the nut is located??
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: upper control arm cam bolts [Re: MRMOPAR] #1232974
05/14/12 06:49 AM
05/14/12 06:49 AM
High Ridge MO.
High Ridge MO.
yes sir thats what I am looking far
Re: upper control arm cam bolts [Re: MOPARCHAS] #1232975
05/14/12 07:17 AM
05/14/12 07:17 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
This is out of a 1972 Service Manual.
Re: upper control arm cam bolts [Re: Leigh] #1232976
05/14/12 08:49 AM
05/14/12 08:49 AM
High Ridge MO.
High Ridge MO.
what I am looking for is pictures of how the accentic washers are facing on some of your cars
thanks Charlie
Re: upper control arm cam bolts [Re: MOPARCHAS] #1232977
05/14/12 09:06 AM
05/14/12 09:06 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Thats all dependent to what it takes to align.
JAKES AUTOMOTIVE
Re: upper control arm cam bolts [Re: JAKE68] #1232978
05/14/12 02:05 PM
05/14/12 02:05 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You use your cam washers to set the alignment.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: upper control arm cam bolts [Re: MOPARCHAS] #1232979
05/14/12 02:22 PM
05/14/12 02:22 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
thanks Charlie
Typically, the bolt head is on the inboard sides of the UCA, with the nuts on the outboard side.
As for the rotational orientation of the eccentrics, that is all over the chart. It varies by each individual car and its caster/camber settings.
The correct position for your car is established by doing a proper front-end alignment.
(Which is what everyone here has been trying to say.)
Down to just a blue car now.
Re: upper control arm cam bolts [Re: 68HemiB] #1232980
05/14/12 04:30 PM
05/14/12 04:30 PM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
On my '66 Coronet 500 Vert the washer is on the inside of the A arm in the wheel well with the nut's facing forward and aft in the engine bay. Does that make sense?
What car are you working on??
Re: upper control arm cam bolts [Re: oldsklharo] #1232981
05/15/12 12:50 AM
05/15/12 12:50 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
This is the factory installation on a 69 A body. This photo shows the driver side with bolt heads inward, nuts outward.
Re: upper control arm cam bolts [Re: kentj340] #1232982
05/15/12 12:57 AM
05/15/12 12:57 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Passenger side front cam bolt head.
Re: upper control arm cam bolts [Re: kentj340] #1232983
05/15/12 01:24 AM
05/15/12 01:24 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Passenger side front cam bolt, nut end.
I have about 1,500 disassembly photos, and that's not enough. I've gotten good use out of my cheap little digital camera.
When I re-assemble, I'll start my alignment with the cams as shown in these photos. This cam position, with the bolt at 12 o'clock on the cam, is the middle position as far as moving the UCA in/out. Consult your FSM, but the middle looks like a good place to start.
BTW, Google youtube videos on DIY front end alignment for some good ideas. The main thing is you need to get all four wheels to the exact same elevation with a level made from plastic tubing and a bucket. Use cheap linoleum squares to shim up your tire pads to the exact same water level in all four places. I think you put a garbage bag under each front wheel so you can steer without upsetting the linoleum squares.
