Re: upper control arm cam bolts
[Re: MOPARCHAS]
#1232973
05/13/12 11:53 PM
05/13/12 11:53 PM
Posts: 2,401 Tucson, Arizona
MRMOPAR
Tucson, Arizona
are you referring to the eccentric position or where the nut is located??
68 RR 528" INDY MAXX
07 2500 CTD
Southwest International Raceway - IHRA - Tucson, AZ
[Re: MOPARCHAS]
#1232977
05/14/12 09:06 AM
05/14/12 09:06 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Thats all dependent to what it takes to align.
JAKES AUTOMOTIVE
[Re: JAKE68]
#1232978
05/14/12 02:05 PM
05/14/12 02:05 PM
Posts: 3,210 robin hood country
deaks
robin hood country
You use your cam washers to set the alignment. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: oldsklharo]
#1232981
05/15/12 12:50 AM
05/15/12 12:50 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
This is the factory installation on a 69 A body. This photo shows the driver side with bolt heads inward, nuts outward.
[Re: kentj340]
#1232983
05/15/12 01:24 AM
05/15/12 01:24 AM
kentj340
Cut and Shoot, TX
Passenger side front cam bolt, nut end.
I have about 1,500 disassembly photos, and that's not enough. I've gotten good use out of my cheap little digital camera.
When I re-assemble, I'll start my alignment with the cams as shown in these photos. This cam position, with the bolt at 12 o'clock on the cam, is the middle position as far as moving the UCA in/out. Consult your FSM, but the middle looks like a good place to start.
BTW, Google youtube videos on DIY front end alignment for some good ideas. The main thing is you need to get all four wheels to the exact same elevation with a level made from plastic tubing and a bucket. Use cheap linoleum squares to shim up your tire pads to the exact same water level in all four places. I think you put a garbage bag under each front wheel so you can steer without upsetting the linoleum squares.
