Page 6 of 10 1 2 4 5 6 7 8 9 10
Re: Should you be able to trust your engine builder? [Re: robnbird] #1230265
05/10/12 04:38 PM
05/10/12 04:38 PM
Finland
mafo Offline
mafo  Offline
Finland
I take the covers off after every single round, and check springs every fifth or so, things happen on these motors and you need to keep an eye on things.
hope it works out for you
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Should you be able to trust your engine builder? [Re: mafo] #1230266
05/10/12 04:54 PM
05/10/12 04:54 PM
Out West
408strokerdart Offline OP
Out West
This thing had a very slow lobe. 36 degrees difference from .020 to .050. Not the aggressive lobes run by so many. This is a bracket motor and we have run three rounds within 15 -20 minutes before so running the valves after every pass just isn't practical. We can put 20 passes on it in 2 days of racing....especially if double entered. I thought lashing the valves every 20 passes was a pretty safe number with this mild cam. New profile is more aggressive so I will change this routine to suit.
Re: Should you be able to trust your engine builder? [Re: Al_Alguire] #1230267
05/10/12 05:16 PM
05/10/12 05:16 PM
tn
robnbird Offline
robnbird  Offline
tn
Well I believe the point here was the OP was tryinig to inform folks of an experience he had with a builder. We see good ones posted all the time here. but rarely the not so good ones. I think after reading all this we can see why. I have no issue with him just taking his stuff somewhere else. I have been in this business for a long time and it happens a lot.
Some people like myself do not like to complain. If we feel we have been treated unfairly or not given what we pay for or feel the level of service is subpar we simply move on and not patronize the business again. The best protest in my opinion is to withold your money from said business. I know that is what I do, live and learn. I will however share my experience with anyone that wants to listen.
His decision to not go back to Shady Dell is his decision. I dont hear him asking to be made whole again. Although I am sure he would cetainly be appreciative. I think the entire point was to share his experience. We have heard both sides of the issue and can all draw our own conclusions.
well I just hate to see stuff like this, and I don't blame Brian for anything he has done. If some guy claims to be a race engine BUILDER , and we are saying race engine. talking the dyno language as if that would have prevented this problem or blaming the lifters. I would not use any part in a RACE motor if I was not %100 confident in that part. If I build a motor and claim to be a Race engine builder and blame the customer for any part I ultimately used then its my fault period. Be responsible for your own definition of who you are. Be responsible. If you ask for fish and get a skunk you will still have some bone head say you deserve the skunk my buddy is the best skunk cook around. NUF SAID
Re: Should you be able to trust your engine builder? [Re: robnbird] #1230268
05/10/12 06:13 PM
05/10/12 06:13 PM
mass,usa
sickhemi Offline
sickhemi  Offline
mass,usa
the builder is responsible for telling the customer what he will and won't use for parts in the engine.i,m sure ryan knew he was building an 8000 rpm bracket motor and if he had a problem with the parts he should have and i think he would refused to use them. would anybody here use eagle i- beam rods in a 8000 rpm bracket motor? you would if you didn't know any better. the engine builder has the final say in the matter. the engine obviously had some problems from being assembled with clearances or parts that you would not find in the builders own engine.
1968 gts 355 r3 six speed efi with irs in progress and 1969 convt 440 stage 6 efi 5spd dana
Re: Should you be able to trust your engine builder? [Re: robnbird] #1230269
05/10/12 07:16 PM
05/10/12 07:16 PM
Vermont
TrWaters Offline
TrWaters  Offline
Vermont
"The biggest reason I didn't contact Ryan was that I was originally taking the heads off for an upgraded port and only seen the lifter parts. Figured that I was going to replace them anyway and yes they were used so why would Ryan do anything about that? The rest of the findings were progressive and got expensive quickly."
So how many passes were made with the broken roller? You didnt detect a skip or a drop in performance?
Alrighty.
Re: Should you be able to trust your engine builder? [Re: TrWaters] #1230270
05/10/12 09:02 PM
05/10/12 09:02 PM
tn
robnbird Offline
robnbird  Offline
tn
Alrighty.
If john force blows a motor who cares but at the local tracks I hate to see a racer loose a motor. valve train is no place to save money. All im saying as a racing engine builder I would NOT build a motor and let it leave my shop with inferior parts. especially valve train. But worse has happened. Im sure this is a good experience for anyone who has followed this post. If building a RACE motor never skimp and use a builder who is very disciplined. Used parts mabe ok for street hot rod , but never a good idea for serious racing. Plus how much can you save on used lifters ( if that was the problem ). Its just to bad for everyone, but especially the racer. he is out for $6500. Im out of here , good luck in the future.
Re: Should you be able to trust your engine builder? [Re: MoparBilly] #1230271
05/10/12 09:59 PM
05/10/12 09:59 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I don't even trust my wife, and I sleep with her every night...trust my engine builder, uhh no, but I still expect to get quality service for my money...
..... ..... ..... now that I have injected some bad humor, Hears my ...... I feel for the OP on a failed engine... but maybe used rollers were not a good choice.... I also feel for all the Moparts people who will probably not benefit from RJs future posts... I know that I have learned a lot over the years and I thank him for that
Re: Should you be able to trust your engine builder? [Re: emarine01] #1230272
05/10/12 10:13 PM
05/10/12 10:13 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
Hey instigator, what has your car run just out of curiousity...........
Was going 5.60's bout 5 years ago with my edelbrock headed smallblock......took a hiatus for a while while I became more involved with wife/new son,family business, and general life.....got car back out again a year ago with about 200 more hp and burnt up the 727 in 5 passes, that I built, going more mph with 6-7 lbs less boost.....I have picked up a new ride, an 87 5th avenue that I am slowly working on and shoehorning the motor into!
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Should you be able to trust your engine builder? [Re: instigator] #1230273
05/10/12 11:37 PM
05/10/12 11:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NICE.......... As for the new car, you are a cccrrraaazzzyyy man...........and I like it!
Re: Should you be able to trust your engine builder? [Re: TrWaters] #1230274
05/11/12 12:07 AM
05/11/12 12:07 AM
Out West
Out West
Alrighty.
This engine didn't make any strange noise. I was more surprised than anyone that it sounded fine. Never so much as a pop or mis fire down track and BTW, the last pass it made was it's quickest by almost .10 in the 1/8th mile. It gave me no reason to suspect anything, but it wouldn't have made many more before being catastrophic.
Re: Should you be able to trust your engine builder? [Re: CHAPPER] #1230275
05/11/12 12:21 AM
05/11/12 12:21 AM
tn
robnbird Offline
robnbird  Offline
tn
I read your response, you state "by looking at the invoice..". I keep notes the whole time I am building an engine, as to any problems, things I have doubts/questions about, etc. It is not on a computer, it is hand written, dated, hour of the day, etc. This has saved me alot of problems over the years. If a customer has a problem with something, or thinks he is having a problem with something, or sees something a year later that he thinks is becoming a problem, I can look back at my notes and usually have a good idea what is happening. I am not busting anybody's chops here, just saying that I need more information than their old invoice when I talk to them. You can be 'REAL' sure, if any used parts, supplied by the customer, were involved in my builds, there will be notes to show that and any reccomendations I gave at the time. Hope this all works out. I have always said, "satisfied customers are never heard from, but, one unhappy customer is heard 'round the world".
EXACTLY
Re: Should you be able to trust your engine builder? [Re: mafo] #1230276
05/11/12 10:05 AM
05/11/12 10:05 AM
tn
robnbird Offline
robnbird  Offline
tn
any new motor should be checked very close just to find any booboos.
Re: Should you be able to trust your engine builder? [Re: robnbird] #1230277
05/11/12 10:11 AM
05/11/12 10:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to check the lash every few rounds when the
engine was new... after the first lash its never
changed... now days I check it 2 times a season...
still hasnt changed... if it keeps changing there
is a problem
Re: Should you be able to trust your engine builder? [Re: MR_P_BODY] #1230278
05/11/12 10:20 AM
05/11/12 10:20 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I check mine twice a season and thats it. Of course its a little B engine and doesn't spin real high. It is always the same everytime.
Again I will say I have no problem with Brian posting this and letting everyone else make their own descion. I think its good to know. For all... Even the builder. If a mistake was made on either end then everyone learns from it. I sure wish it wasn't a $6,500 leason for Brian but I'm sure he learned though. It just reinforces to check everything. I have no problem pulling the pan, covers, intake, whatever on a need motor and checking stuff. I don't trust anyone. I just wish it would work out for Brian in the end.
Re: Should you be able to trust your engine builder? [Re: Al_Alguire] #1230279
05/11/12 04:13 PM
05/11/12 04:13 PM
tn
robnbird Offline
robnbird  Offline
tn
If you are paying your hard earned money to an engine builder for a complete ready to go engine I would expect that things are machined and assembled correctly. In this case that is not what happened. Parts failures happen, but errors and damaged parts caused from incorrect machining, or incorrect assembly or lack of attention to detail are unacceptable. I know when we do work for customers if it is not right we make it right, at the agreed cost. Even if that means we do not make any money on the job. Right is right period.
A good name is able to be chosen.
Re: Should you be able to trust your engine builder? [Re: robnbird] #1230280
05/11/12 08:29 PM
05/11/12 08:29 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I trusted said builder, and guess what?? I had motor rebuilt before I even made a run. At $30.000 plus I'm not taking chances. Others on this site know my motor and seen first hand as build was going on, I quote " I feel sorry for the sucker getting that motor" me being the sucker
Re: Should you be able to trust your engine builder? [Re: mokid] #1230281
05/12/12 11:36 AM
05/12/12 11:36 AM
MIKECS Offline
MIKECS  Offline
THE BEST THING TO DO IS LEARN HOW TO BUILD THE ENGINE YOURSELF. TRUST NO ONE CHECK EVERYTHING ONCE OR TWICE OR THREE.
I WAS IN A SIMULAR PLACE YOU WERE. I BOUGHT ALL MY OWN SUNNEN CHECKING TOOLS, VALVE GRINDER, SEAT,ETC. I DO NOT WANT TO DEPEND ON ANYONE TO CHECK MY MEASUREMENTS.
I WAS TIRED OF NOT CHECKING PRIME AND LOOSEING IT TO HALF A ENGINE, BOLTS NOT TORQUED PROPERLY, BOLTS COMING LOOSE. THE LIST GOES ON. I KNOW MORE MY ENGINE AND HOW TO BUILD IT THAN THE GUY I HAD DOING IT AND I KNEW HIM FOR A LONG TIME.
Re: Should you be able to trust your engine builder? [Re: 408strokerdart] #1230282
05/12/12 01:20 PM
05/12/12 01:20 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I've been following this story since I bought what was left of
Brian's W-5 short block.
I've learned several things about this "race engine business"
over the years. Some, at my expense. Some, at the expense
of others. Most, from observation.
When you pay to have a job done and it doesn't get done correctly,
it's been my thought that it won't be done correctly for FREE.
I've also came to the conclusion, most successful class racers build
their own engines for a reason. You can't hardly pay some people
enough to care about your engine.
I don't mind being a non-conformist.
Re: Should you be able to trust your engine builder? [Re: S/ST 3040] #1230283
05/12/12 01:29 PM
05/12/12 01:29 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
But you do work for other people's engines right? If this REALLY is your philosophy, why should I trust you with building an engine or doing a simple valve job?
Re: Should you be able to trust your engine builder? [Re: Hot 340] #1230284
05/12/12 01:40 PM
05/12/12 01:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
OUCH.................Valid point though..........I trust no one 100% including myself that way I`m never dissapointed......Peace.
