shaker bubble to base plate? #1230059
05/08/12 11:37 PM
05/08/12 11:37 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
what actually holds the two togeather ? is it just a seal? is the grip that holds them togeather enuff to hold them while base plate bolted to wall???
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: shaker bubble to base plate? [Re: toplescuda] #1230060
05/09/12 12:33 AM
05/09/12 12:33 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
There are several capscrews that hold the bubble to the adapter ring.
Re: shaker bubble to base plate? [Re: 70440+6bbl] #1230061
05/09/12 01:41 AM
05/09/12 01:41 AM
missouri poplar bluff
lady426 Offline
lady426  Offline
Anyone got pic/s showing the location and details?
1974 rallye challenger plum crazy with a 426 dual plug hemi
Re: shaker bubble to base plate? [Re: lady426] #1230062
05/09/12 02:09 AM
05/09/12 02:09 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: shaker bubble to base plate? [Re: DAYCLONA] #1230063
05/09/12 08:21 AM
05/09/12 08:21 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Lol thanks but that dont help much
1971 charger
Re: shaker bubble to base plate? [Re: toplescuda] #1230064
05/09/12 10:43 AM
05/09/12 10:43 AM
PNW
Danan Offline
Danan  Offline
PNW
The baseplate bolts to the adapter ring, the bubble bolts to the adapter ring. Reference the drawing Dayclona posted.
Re: shaker bubble to base plate? [Re: Danan] #1230065
05/09/12 11:21 AM
05/09/12 11:21 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Bubble was held down to the adapter ring with 10-24 sems screws with captive washers
Re: shaker bubble to base plate? [Re: gtx6970] #1230066
05/09/12 11:38 AM
05/09/12 11:38 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
... at 7 locations...
Re: shaker bubble to base plate? [Re: toplescuda] #1230067
05/09/12 06:26 PM
05/09/12 06:26 PM
Kennewick, Wa.
71vert340 Offline
71vert340  Offline
Kennewick, Wa.
And the base plate sits on top of the carb just like the bottom of an air cleaner assembly does. The filter sits on top of it and the air filter lid clamps it all together on the carb(s). Two feet mounted on the front of the base plate bolt to the front of the engine.
Re: shaker bubble to base plate? [Re: xs29j8] #1230068
05/09/12 09:00 PM
05/09/12 09:00 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
thats the pic i was needing i had all the rest just never mounted the bouble
1971 charger
Re: shaker bubble to base plate? [Re: xs29j8] #1230069
05/09/12 09:10 PM
05/09/12 09:10 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Being the car its going on is a non shaker car i had bought base plate and adapter ring and bubble from year one ( all fiberglass) so there is no holes on any of it im assuming the still ring had j clips the bolts threaded into guiess il just have to drill and use nut/bolt?
1971 charger
Re: shaker bubble to base plate? [Re: toplescuda] #1230070
05/15/12 05:27 PM
05/15/12 05:27 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Can anyone post some shots (on real cars) showing how much the seal does or does not cover the bolts and possible one or two showing the bubble off but base and adapter ring still on
Thanks guys
1971 charger
Re: shaker bubble to base plate? [Re: toplescuda] #1230071
05/17/12 07:50 PM
05/17/12 07:50 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: shaker bubble to base plate? [Re: toplescuda] #1230072
05/17/12 09:07 PM
05/17/12 09:07 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Once the bubble is installed - it covers the screws holding the base to the adapter ring, but all the screws holding the bubble to the ring are clearly visible
Re: shaker bubble to base plate? [Re: gtx6970] #1230073
05/18/12 09:00 AM
05/18/12 09:00 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Are the seven bolts required available as repo's from anyone?
Re: shaker bubble to base plate? [Re: TiMopar] #1230074
05/18/12 09:54 AM
05/18/12 09:54 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Year One carries them at about $50/Set... I believe some radiator shroud attaching bolts were the same or very similar...
Re: shaker bubble to base plate? [Re: TiMopar] #1230075
05/18/12 10:53 AM
05/18/12 10:53 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Sure is - $25 a set of 7
Re: shaker bubble to base plate? [Re: gtx6970] #1230076
05/20/12 12:24 AM
05/20/12 12:24 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you would be looking for convenience rather than correctness, I always run screws up from the bottom so that they stick up through the bubble. Then use little wing nuts on the threaded end of the screws.
I learned that way back when I had my Shaker hooded 6 BBl Cuda. Everybody wanted to see the carbs and intake. And taking the Shaker off with the original screws running down through the bubble meant I had to carry a nut driver. It was just a pain.
On that car and my current Cuda, I just keep wing nuts on screws run up through the threaded holes on the 4 corners. That way it only takes a minute to spin them off, then the wing nuts on the air cleaner lid and the wing nut on the carb and it's off.
This will also be a life saver while tuning the beast.
Just a suggestion.
Master, again and still
Re: shaker bubble to base plate? [Re: DaveRS23] #1230077
05/20/12 12:44 AM
05/20/12 12:44 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just a suggestion.
Agreed, I do the same, but with knurled thumb nuts, makes bubble removal easy and quick
