shaker bubble to base plate?
#1230059
05/08/12 11:37 PM
05/08/12 11:37 PM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
what actually holds the two togeather ? is it just a seal? is the grip that holds them togeather enuff to hold them while base plate bolted to wall???
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: shaker bubble to base plate?
[Re: lady426]
#1230062
05/09/12 02:09 AM
05/09/12 02:09 AM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1230063
05/09/12 08:21 AM
05/09/12 08:21 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
Lol thanks but that dont help much
[Re: gtx6970]
#1230066
05/09/12 11:38 AM
05/09/12 11:38 AM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
Bubble was held down to the adapter ring with 10-24 sems screws with captive washers
... at 7 locations...
[Re: xs29j8]
#1230069
05/09/12 09:10 PM
05/09/12 09:10 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Being the car its going on is a non shaker car i had bought base plate and adapter ring and bubble from year one ( all fiberglass) so there is no holes on any of it im assuming the still ring had j clips the bolts threaded into guiess il just have to drill and use nut/bolt?
[Re: toplescuda]
#1230070
05/15/12 05:27 PM
05/15/12 05:27 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Can anyone post some shots (on real cars) showing how much the seal does or does not cover the bolts and possible one or two showing the bubble off but base and adapter ring still on Thanks guys
[Re: toplescuda]
#1230071
05/17/12 07:50 PM
05/17/12 07:50 PM
Posts: 18,157 Mass
DAYCLONA
Mass
[Re: TiMopar]
#1230074
05/18/12 09:54 AM
05/18/12 09:54 AM
xs29j8
Fort Worth, Texas
Are the seven bolts required available as repo's from anyone?
Year One carries them at about $50/Set... I believe some radiator shroud attaching bolts were the same or very similar...
[Re: TiMopar]
#1230075
05/18/12 10:53 AM
05/18/12 10:53 AM
Posts: 21,447 It's a dry heat
gtx6970
It's a dry heat
Sure is - $25 a set of 7
[Re: gtx6970]
#1230076
05/20/12 12:24 AM
05/20/12 12:24 AM
Posts: 12,160 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
If you would be looking for convenience rather than correctness, I always run screws up from the bottom so that they stick up through the bubble. Then use little wing nuts on the threaded end of the screws. I learned that way back when I had my Shaker hooded 6 BBl Cuda. Everybody wanted to see the carbs and intake. And taking the Shaker off with the original screws running down through the bubble meant I had to carry a nut driver. It was just a pain. On that car and my current Cuda, I just keep wing nuts on screws run up through the threaded holes on the 4 corners. That way it only takes a minute to spin them off, then the wing nuts on the air cleaner lid and the wing nut on the carb and it's off. This will also be a life saver while tuning the beast. Just a suggestion.
Master, again and still
[Re: DaveRS23]
#1230077
05/20/12 12:44 AM
05/20/12 12:44 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Just a suggestion.
Agreed, I do the same, but with knurled thumb nuts, makes bubble removal easy and quick
