Fuel system with return line. #1229555
05/08/12 03:19 PM
05/08/12 03:19 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I am curious about what press regulator some of you are using on carb systems when using a return line setup ? Is it a reg with the return line fitting on it ? Ron
Re: Fuel system with return line. [Re: 383man] #1229556
05/08/12 03:22 PM
05/08/12 03:22 PM
an8sec70cuda Offline
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fuel system with return line. [Re: an8sec70cuda] #1229557
05/08/12 03:27 PM
05/08/12 03:27 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Re: Fuel system with return line. [Re: 383man] #1229558
05/08/12 04:58 PM
05/08/12 04:58 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there are plenty of them out there and i'm sure a lot of pretty good ones. though i've never used one of these i think it's a nice setup
Re: Fuel system with return line. [Re: 383man] #1229559
05/08/12 05:03 PM
05/08/12 05:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m running the recommended return style reg. w/my Magnafuel 300 pump and what a difference over my other set-up.
Re: Fuel system with return line. [Re: 383man] #1229560
05/08/12 05:21 PM
05/08/12 05:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mallory 4 port with return... been on my car since
day one
Re: Fuel system with return line. [Re: MR_P_BODY] #1229561
05/08/12 05:49 PM
05/08/12 05:49 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Fuel system with return line. [Re: Triple Threat] #1229562
05/09/12 11:29 AM
05/09/12 11:29 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the replies. I am considering going to the return line setup. Ron
Re: Fuel system with return line. [Re: 383man] #1229563
05/09/12 11:56 AM
05/09/12 11:56 AM
Driving on the street w/ junk pump gas, I'd strongly recommend it!
CHIP
Re: Fuel system with return line. [Re: sixpackgut] #1229564
05/09/12 12:41 PM
05/09/12 12:41 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Re: Fuel system with return line. [Re: SLOW67] #1229565
05/09/12 01:12 PM
05/09/12 01:12 PM
Indiana
BM70Dart Offline
BM70Dart  Offline
Indiana
I have a holley blue pump and holley return style reg simple setup worksgood on my car
Re: Fuel system with return line. [Re: 383man] #1229566
05/09/12 01:45 PM
05/09/12 01:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Let me just say that some pumps like the Aeromotive I had before although it said it could run a return, could NOT keep up to my engine`s demands........PERIOD.
Re: Fuel system with return line. [Re: SLOW67] #1229567
05/09/12 03:18 PM
05/09/12 03:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Rich H.
Esse Quam Videri
Re: Fuel system with return line. [Re: an8sec70cuda] #1229568
05/09/12 07:45 PM
05/09/12 07:45 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I starting have a few problems this year and it seems to be from this cheap pump gas. I had the fuel seem like it was perking when I was around 190 and then it pushed the fuel out the bowl vents and flooded. I got it started and then drove it 20 miles home but it has done this 3 times out of nowhere and only when the car is good and hot. I actually installed a cool can and last time out I went 90 miles with no trouble putting an ice pack in the cool can. So if a return setup will keep the fuel cooler then I think I will go with it. I heard the pump gas was not going to be as good this year with more ethanal. Thanks again , Ron
Re: Fuel system with return line. [Re: 383man] #1229569
05/11/12 01:51 AM
05/11/12 01:51 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
I have this exact same problem, and it started as soon as the winter blend gas went away. It is aggravating as all heck!! Mine only percolates in the rear bowl though. The front must move enough fuel during cruise to keep it from happening.
As soon as I try to make a WOT Run, it eats all the front bowl, and gets to the back and just sorta shuts off. I can see the gas boiling through the sight glass.
I am also looking at building a return style system to cure it.
Re: Fuel system with return line. [Re: redmist] #1229570
05/11/12 09:30 AM
05/11/12 09:30 AM
I first ran into this problem a couple years ago. Driving home from work (65 mph on the highway mostly) I stopped at the gas station, then the car was a bear to refire. Flooding out, would run briefly then die, blah blah blah. Had that happen a couple of times after that before I broke down and spent the money on a bigger pump, regulator, lines, etc. It was definitely worth the money.
Only time I've had an issue w/ it recently was during the True Street race at Rockingham a few weeks ago. We had to do a 10 mile drive, then pull into the lanes w/ NO cool down time and do 3 back to back hot laps down the 1/4 mile. I didn't have enough fuel in the tank so it started recirculating hot fuel...it used more than I anticipated. By my last pass it almost died coming out the water box from the fuel being so hot and trying to vapor-lock. It ran 3 dead on 10.01 at 135 mph passes w/ a broken torque converter and won the class, so I wasn't too upset, lol.
CHIP
Re: Fuel system with return line. [Re: redmist] #1229571
05/11/12 09:47 AM
05/11/12 09:47 AM
jamesc Offline
jamesc  Offline
the RVP of winter blend gasoline is higher that that of summer to aid in vaporization, winter blend would be much more likely to have vapor locking and boiling problems.
just curious how many if any of the guys having these types of problems are running some type of insulator under the carb?
Re: Fuel system with return line. [Re: jamesc] #1229572
05/11/12 09:53 AM
05/11/12 09:53 AM
I have a 1" wood spacer under the carb.
CHIP
Re: Fuel system with return line. [Re: 383man] #1229573
05/11/12 10:06 AM
05/11/12 10:06 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
FWIW
I run a mechanical pump and factory style vapor separator with a return line. I have driven my cars all over the country in very extreme conditions and with all different kinds of gas. My car's fuel system is quiet, stock and dead reliable and would be easy to get parts for anywhere.
I don't need all that fancy racing stuff on my street car. How many of you can say you've driven your car at near wide open throttle for miles at a time, like over 5 miles at a time in 95 degree weather at 6000 feet alitutde? It never ran out of gas. I also drove it in 115 degree temps in Vegas last summer with the AC running the whole time.
I don't need no stinking vapor locking electric fuel pump on my street driven muscle car.
My carbs is bolted right to the intake manifold with no spacer/bandaid.
Re: Fuel system with return line. [Re: jamesc] #1229574
05/11/12 10:19 AM
05/11/12 10:19 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I ran a wood spacer on my 340 to stop percolation, it sounded like a coffee pot a few minutes after I shut it off.
When I built the 408 I ran a 1/2" line up the inside of the frame rail to the regulator (non return)from the Holley billet black pump. In real hot weather the car would do the same thing as Rons, it would boil the gas and flood going down the highway. My car has air pans sealing up the front and the carb was sealed to the hood so pretty much the only air going through the engine bay came through the radiator. I fabricated a shield for the line where it passed by the header and removed the air pan sealing the hood but it would still do it in very hot weather.
The fix for me was to route the fuel line over the frame tie behind the trans crossmember, through the inner fender into the wheelwell on the passengers side and through a bulkhead fitting in the front of the inner fender to the regulator mounted there. I also replaced the 3/8" line from the regulator to the carb with 8AN. No issues since, my heat was coming form the headers and the lack of airflow in the engine bay compounded the problem. BYW I'm still using the Holley deadhead regulator.
