Install 383 valley pan with or without 4 facing pieces. #1216075
04/15/12 10:25 AM
04/15/12 10:25 AM
Dallas, Wisconsin
BurntOrange Offline OP
Dallas, Wisconsin
I've always just used the valley pan itself with a little RTV at the corners. Been awhile. I see kits with the 4 - .030 facing pieces. Any advantage either way?
Re: Install 383 valley pan with or without 4 facing pieces. [Re: BurntOrange] #1216076
04/15/12 10:32 AM
04/15/12 10:32 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the only time i would use the papers is if the manifold has been machined for them.
Re: Install 383 valley pan with or without 4 facing pieces. [Re: BurntOrange] #1216077
04/15/12 10:34 AM
04/15/12 10:34 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I just use the pan itself with with sealer on the ends and corners
Gus
64 Plymouth Savoy
Dana 60
Re: Install 383 valley pan with or without 4 facing pieces. [Re: fourgearsavoy] #1216078
04/15/12 10:43 AM
04/15/12 10:43 AM
Dallas, Wisconsin
Dallas, Wisconsin
No spacers . . . got it. THANKS!
