sb valve spring #1215894
04/14/12 11:35 PM
04/14/12 11:35 PM
bc canada
67valiant Offline OP
bc canada
looking to find a set of springs that are 200 on the seat 500 min installed that have a dia of 1.50 or lower to clear my crane gold roller rockers my head guys say i need that pressure for my billet solid roller cam sounds high dont ya think as i look at other cams for springs
Re: sb valve spring [Re: 67valiant] #1215895
04/14/12 11:52 PM
04/14/12 11:52 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Doesn't sound high for a solid roller. Mine are 240 @ 1.900 and 598 @ 1.15"
Comp 943-16's
I guess it would depend on the profile , but those numbers you want are near the bottom of the scale with solid roller cams.
Your installed height would be helpful.
I wouldn't look to save money here though.......expect to drop somewhere around three bills for quality.
Re: sb valve spring [Re: tubtar] #1215896
04/15/12 12:36 AM
04/15/12 12:36 AM
bc canada
bc canada
yup going with good stuff just need them to clear the rockers we were looking at the comp 938 204&1.90 516&1.25 as they are 1.539 od but there still a lil close he says
Re: sb valve spring [Re: 67valiant] #1215897
04/15/12 09:04 AM
04/15/12 09:04 AM
ont,canada
mopartuner Offline
mopartuner  Offline
ont,canada
I ran the comp 938 speings with a solid roller and my cam was 640 lift 265@.050 worked well.
410 pump gas solis flat tappet cam 10.95 so far
Re: sb valve spring [Re: mopartuner] #1215898
04/15/12 01:27 PM
04/15/12 01:27 PM
bc canada
bc canada
opps ya my cam profile is 600 lift 268@50
Re: sb valve spring [Re: 67valiant] #1215899
04/15/12 09:56 PM
04/15/12 09:56 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
personalty I would want more spring than that on a solid roller.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: sb valve spring [Re: dusturbd340W5] #1215900
04/16/12 08:49 AM
04/16/12 08:49 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
These are close to what you are looking for, with a 1.85 installed height (197 seat and 533 open @ 0.600 lift).
http://www.summitracing.com/parts/LUN-73899LUN/
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: sb valve spring [Re: 67valiant] #1215901
04/16/12 04:35 PM
04/16/12 04:35 PM
Ont. Canada
10.90 Racer Offline
super street
10.90 Racer  Offline
super street
Ont. Canada
200 on the seat is not very much with a solid roller.......... 240 250 would be nice...
Re: sb valve spring [Re: 10.90 Racer] #1215902
04/16/12 04:45 PM
04/16/12 04:45 PM
Guitar Jones Offline
I asked Chaz Knight about running my Crane Golds with the solid roller. I was about 700 open pressure and he told me the rockers were not recommended for over 600 open pressure, So I just got HS rockers instead but I still went down on the open pressure to about 645. Personally I think you need more spring pressure than 500 and a better rocker arm. I know, sucked for me too.
Re: sb valve spring [Re: Guitar Jones] #1215903
04/17/12 01:53 AM
04/17/12 01:53 AM
bc canada
bc canada
thanks for you help guys ya im looking into t&d rocker go big or go home right just where to buy them now
Re: sb valve spring [Re: 67valiant] #1215904
04/17/12 08:39 AM
04/17/12 08:39 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Competition Products is a stocking dealer , though they probably won't have MoPar in stock. But their prices were pretty friendly.
www.competitionproducts.com
I got mine through them and the price was the lowest I found anywhere , even having to order the parts. Pretty quick turn around too.....a week as I recall.
I don't know what to tell you about the duty for international orders , but I do have some theories as to how to minimize it.
I have a handful of friends up there and any transaction can be a challenge.
