Re: sb valve spring
[Re: tubtar]
#1215896
04/15/12 12:36 AM
04/15/12 12:36 AM
Posts: 378 bc canada
67valiant
bc canada
yup going with good stuff just need them to clear the rockers we were looking at the comp 938 204&1.90 516&1.25 as they are 1.539 od but there still a lil close he says
Re: sb valve spring
[Re: 67valiant]
#1215897
04/15/12 09:04 AM
04/15/12 09:04 AM
Posts: 614 ont,canada
mopartuner
ont,canada
I ran the comp 938 speings with a solid roller and my cam was 640 lift 265@.050 worked well.
410 pump gas solis flat tappet cam 10.95 so far
Re: sb valve spring
[Re: 67valiant]
#1215899
04/15/12 09:56 PM
04/15/12 09:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
personalty I would want more spring than that on a solid roller.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: sb valve spring
[Re: dusturbd340W5]
#1215900
04/16/12 08:49 AM
04/16/12 08:49 AM
Posts: 1,178 Indy
FlyFish
Indy
These are close to what you are looking for, with a 1.85 installed height (197 seat and 533 open @ 0.600 lift). http://www.summitracing.com/parts/LUN-73899LUN/
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: sb valve spring
[Re: 10.90 Racer]
#1215902
04/16/12 04:45 PM
04/16/12 04:45 PM
Guitar Jones
I asked Chaz Knight about running my Crane Golds with the solid roller. I was about 700 open pressure and he told me the rockers were not recommended for over 600 open pressure, So I just got HS rockers instead but I still went down on the open pressure to about 645. Personally I think you need more spring pressure than 500 and a better rocker arm. I know, sucked for me too.
Re: sb valve spring
[Re: 67valiant]
#1215904
04/17/12 08:39 AM
04/17/12 08:39 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
Competition Products is a stocking dealer , though they probably won't have MoPar in stock. But their prices were pretty friendly. www.competitionproducts.comI got mine through them and the price was the lowest I found anywhere , even having to order the parts. Pretty quick turn around too.....a week as I recall. I don't know what to tell you about the duty for international orders , but I do have some theories as to how to minimize it. I have a handful of friends up there and any transaction can be a challenge.
