Factory Assembly VIN ?
#1213485
04/10/12 09:52 AM
04/10/12 09:52 AM
Posts: 1,647 IL
71383beep
IL
I was looking at a 71 B Body the other day and the owner pointed out something very strange to me. He pointed out that to his knowledge the drivetrain was all original and it certainly appeared that way but the part VIN stamping on the motor and tranny (which matched) were a few hundred digits off of the VIN on the vehicle. They both had the same initial numbers at 1E106...but the last 3 digits were different.
I was wondering what the factory process was that could explain this. It sounds like a different motor and tranny were grabbed and placed on the k wherever the K frame sub assemblies were assembled. Is that possible? Or was the VIN stamped in after the sub assembly was installed?
The reason I ask is that the claim is #'s matching but they clearly don't. However, on the flip side how likely is it that a complete drivetrain from another closely matched VIN built from the same plant at about the same time is transplanted into the car?
Has anyone else encountered such a thing?
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Factory Assembly VIN ?
[Re: ScottSmith_Harms]
#1213489
04/10/12 02:19 PM
04/10/12 02:19 PM
Posts: 1,647 IL
71383beep
IL
Okay so I am not the only one then.
So when were the numbers stamped in? I am imagining an assembly area where the motor and tranny are mated to the k and the whole thing is wheeled/hoisted etc over to the car. Is this about right? Do they punch numbers prior to the car, on the car, before going on the K?
For some reason I find this an intersting subject.
I am imagining that the guys assembling the car knew they needed a N code Auto w/ air grabber they go over to grab one and accidentally grab one for another car and hoist it in and that's that...switched numbers.
Why is LA such an oddball. I know they closed soon after the 71 models were done. Was QC a big issue there?
[Re: 71383beep]
#1213490
04/10/12 02:33 PM
04/10/12 02:33 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
The engine/trans, front suspension, driveshaft, rear axle, leaf springs and exhaust were all installed onto a cart and sent down the line. The bodies were up in the air on a conveyor and were dropped over the drivetrain assemblies. The engine and trans were stamped after they were bolted together but probably before they were installed on the carts. Someone will correct me if I'm wrong. I still say the line worker didn't have the stamp setup right and got a few numbers wrong. http://www.hamtramck-historical.com/images/misc/robin2.jpg
[Re: 71383beep]
#1213492
04/10/12 11:06 PM
04/10/12 11:06 PM
Posts: 461 Texas
Ron69rr
Texas
I see well that is interesting.
The issue with the mis stamped Vin is that the numbers are not even the same digits its 594 vs 170. The mis stamp you pointed out seems very likely where as this is not as much. That is why i am thinking the guy either forgot to change the stamp or maybe the motor and trans were intended for another 383 AG auto car.
Interesting!
What I find interesting is there is only 2 workers to put the unit together.
Post deleted by moparts
[Re: 71383beep]
#1213494
04/11/12 12:10 AM
04/11/12 12:10 AM
