Factory Assembly VIN ? #1213485
04/10/12 09:52 AM
04/10/12 09:52 AM
IL
71383beep Offline OP
IL
I was looking at a 71 B Body the other day and the owner pointed out something very strange to me. He pointed out that to his knowledge the drivetrain was all original and it certainly appeared that way but the part VIN stamping on the motor and tranny (which matched) were a few hundred digits off of the VIN on the vehicle. They both had the same initial numbers at 1E106...but the last 3 digits were different.
I was wondering what the factory process was that could explain this. It sounds like a different motor and tranny were grabbed and placed on the k wherever the K frame sub assemblies were assembled. Is that possible? Or was the VIN stamped in after the sub assembly was installed?
The reason I ask is that the claim is #'s matching but they clearly don't. However, on the flip side how likely is it that a complete drivetrain from another closely matched VIN built from the same plant at about the same time is transplanted into the car?
Has anyone else encountered such a thing?
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Factory Assembly VIN ? [Re: 71383beep] #1213486
04/10/12 10:05 AM
04/10/12 10:05 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The guy that stamped it probably set up the machine wrong. My VIN 159366 is stamped wrong on the trans.(I havn't looked at the block yet but I assume it's wrong too...the same punch was used) Mine says 159369.
Re: Factory Assembly VIN ? [Re: burdar] #1213487
04/10/12 10:53 AM
04/10/12 10:53 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Were the last 3 #'s similar, or easy to transpose? Say 959 instead of 656? Anything is possible. I see its an early LA built car. There were some funky things going on with VIN stamping there, heres my trans#
Re: Factory Assembly VIN ? [Re: NV69B7RR] #1213488
04/10/12 11:28 AM
04/10/12 11:28 AM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Yes, LA cars are oddballs, I have a confirmed an original 71 340 4 speed Demon as original and numbers matching, the trans never got stamped at all! Another 1971 Demon trans stamping looked similar to the example above, not very readable but 100% authentic.
Mistakes like described by the original poster did happen. It makes authentication difficult but usually there are other clues to help determine the cars originallity.
Re: Factory Assembly VIN ? [Re: ScottSmith_Harms] #1213489
04/10/12 02:19 PM
04/10/12 02:19 PM
IL
IL
Okay so I am not the only one then.
So when were the numbers stamped in? I am imagining an assembly area where the motor and tranny are mated to the k and the whole thing is wheeled/hoisted etc over to the car. Is this about right? Do they punch numbers prior to the car, on the car, before going on the K?
For some reason I find this an intersting subject.
I am imagining that the guys assembling the car knew they needed a N code Auto w/ air grabber they go over to grab one and accidentally grab one for another car and hoist it in and that's that...switched numbers.
Why is LA such an oddball. I know they closed soon after the 71 models were done. Was QC a big issue there?
Re: Factory Assembly VIN ? [Re: 71383beep] #1213490
04/10/12 02:33 PM
04/10/12 02:33 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The engine/trans, front suspension, driveshaft, rear axle, leaf springs and exhaust were all installed onto a cart and sent down the line. The bodies were up in the air on a conveyor and were dropped over the drivetrain assemblies.
The engine and trans were stamped after they were bolted together but probably before they were installed on the carts. Someone will correct me if I'm wrong. I still say the line worker didn't have the stamp setup right and got a few numbers wrong.
http://www.hamtramck-historical.com/images/misc/robin2.jpg
Re: Factory Assembly VIN ? [Re: burdar] #1213491
04/10/12 03:38 PM
04/10/12 03:38 PM
IL
IL
I see well that is interesting.
The issue with the mis stamped Vin is that the numbers are not even the same digits its 594 vs 170. The mis stamp you pointed out seems very likely where as this is not as much. That is why i am thinking the guy either forgot to change the stamp or maybe the motor and trans were intended for another 383 AG auto car.
Interesting!
Re: Factory Assembly VIN ? [Re: 71383beep] #1213492
04/10/12 11:06 PM
04/10/12 11:06 PM
Texas
Ron69rr Offline
Ron69rr  Offline
Texas
Interesting!
What I find interesting is there is only 2 workers to put the unit together.
Re: Factory Assembly VIN ? [Re: Ron69rr] #1213493
04/11/12 12:09 AM
04/11/12 12:09 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Theres a 3rd guy in the picture.
Post deleted by moparts [Re: 71383beep] #1213494
04/11/12 12:10 AM
04/11/12 12:10 AM
Re: Factory Assembly VIN ? #1213495
04/11/12 12:42 AM
04/11/12 12:42 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Troy just bought a 69 Swinger 340 built at the L.A. plant that has a numbers matching oil pan. Missed the block entirely.
I saw a 70 Hemi Cuda recently that they hit the VIN high on the casted part of the block. That's a Hamtramck built car.
