leaky trans pan gasket #1212488
04/09/12 12:44 AM
04/09/12 12:44 AM
Wi.
65_gt_rag_402 Offline OP
Wi.
say what are you guys using for the trans pan gasket on a 727 ?
buddys car leaked with the rubber gasket and we tried a cork with both side permatex high temp orange sealer and still leaked..
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: leaky trans pan gasket [Re: 65_gt_rag_402] #1212489
04/09/12 01:07 AM
04/09/12 01:07 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
You must make sure the pan is flat flat flat....especially around the bolt holes. The trick gasket to use the steel core rubber gasket for a 518 (P2464324). That said I have yet to see a trans pan that leaked because of the gasket. Usually the pan is the culprit.
I wonder if Quaden still has any on the shelf left over from the dealership days?
Re: leaky trans pan gasket [Re: 65_gt_rag_402] #1212490
04/09/12 01:08 AM
04/09/12 01:08 AM
Va. Beach, Va
69superbee383 Offline
Va. Beach, Va
I have been using one of the new reusable ones from Mopar
http://www.ebay.com/itm/Mopar-Lifetime-7...b5e&vxp=mtr
77 Macho Power Wagon LWB factory 440 70 Coronet 440 N code 3 speed
Re: leaky trans pan gasket [Re: 69superbee383] #1212491
04/09/12 01:17 AM
04/09/12 01:17 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Ditto... Those things are awesome. Should be a stocking item at any dealership if you got one locally.
Re: leaky trans pan gasket [Re: 135sohc] #1212492
04/09/12 01:27 AM
04/09/12 01:27 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Likewise, but that said, I'm using mine with a cast aluminum pan with a thick flange. Dry as a bone on the outside, after a couple of on/off cycles.
Re: leaky trans pan gasket [Re: MoparMarq] #1212493
04/09/12 08:23 AM
04/09/12 08:23 AM
Andrewh Offline
Andrewh  Offline
also be sure it is the pan gasket leaking.
I once thought that was what I was chasing down, went through 3 gaskets, 2 pans and thought it was still leaking, turned out to be the shaft seal.
others have seen it be the 0 ring at the dipstick tube.
don't waste a lot of time and money on the pan if you have not checked above it yet.
Re: leaky trans pan gasket [Re: Andrewh] #1212494
04/09/12 08:37 AM
04/09/12 08:37 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
No gasket and just use permatex the right stuff. follow the directions never had one leak in 5 years.
Re: leaky trans pan gasket [Re: Scamp408] #1212495
04/09/12 05:55 PM
04/09/12 05:55 PM
Wi.
Wi.
Thanks for all your responses on this issue you guys ..
has anyone ever tried permatex ultra Black gasket sealer ? .. it's Suppose to work good too on gaskets .. but Heard it dries hard and very hard to scrape off later .
heard the "right stuff" is good Too.
Thanks !
Re: leaky trans pan gasket [Re: Andrewh] #1212496
04/09/12 06:22 PM
04/09/12 06:22 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Same here(after 2 different pans & installing reusable gasket),it was the shaft seal,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: leaky trans pan gasket [Re: 65_gt_rag_402] #1212497
04/09/12 06:28 PM
04/09/12 06:28 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
Gravity is a funny thing , what may APPEAR to be the pan gasket leaking could be coming from a source above the pan ... and there are a few ... cooler line fittings , dipstick tube , shift shaft seals ...
Also if he has a chrome pan and has not removed the chrome from the gasket flange he is never going to get it to seal short of welding the pan to the trans.
Re: leaky trans pan gasket [Re: JohnRR] #1212498
04/09/12 07:40 PM
04/09/12 07:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
2X especially that pesky o-ring on the tube!
Re: leaky trans pan gasket [Re: mikemee1331] #1212499
04/09/12 08:28 PM
04/09/12 08:28 PM
BDW Offline
BDW  Offline
I'd be willing to bet it's not the gasket, I changed mine 3-4 times.
Finally discovered it was 3-4 OTHER places making it look like the gasket.
Re: leaky trans pan gasket [Re: Andrewh] #1212500
04/09/12 09:11 PM
04/09/12 09:11 PM
crlush Offline
crlush  Offline
thought my gasket was leaking turned out it was the dipstick oring.
Re: leaky trans pan gasket [Re: JohnRR] #1212501
04/09/12 11:35 PM
04/09/12 11:35 PM
Wi.
Wi.
Hahahaha .......everything is clean and dry around the pan area except where it is leaking .. It's not a chrome pan either ...guess that's a plus but yeah........ those seem to leak always for some reason .
Re: leaky trans pan gasket [Re: mikemee1331] #1212502
04/09/12 11:38 PM
04/09/12 11:38 PM
Wi.
Wi.
NOPE .........not the o-ring on the dip tube .. even that was permatexted when Installed the 727 a year ago.. That is nice and dry there.
Re: leaky trans pan gasket [Re: BDW] #1212503
04/09/12 11:41 PM
04/09/12 11:41 PM
Wi.
Wi.
no........ leaking right on the front edge of the trans plain as day and a drip on both the bolts that hold the manual shift cable to the pan with the 3/8" spacers..
Re: leaky trans pan gasket [Re: 65_gt_rag_402] #1212504
04/09/12 11:47 PM
04/09/12 11:47 PM
Wi.
Wi.
buy the way............ it's not a deep pan OR Aluminum pan just the stock/standard depth 727 Pan.
Re: leaky trans pan gasket [Re: 65_gt_rag_402] #1212505
04/10/12 12:07 AM
04/10/12 12:07 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'd guess you have a leak other than the pan gasket,as either the cork or rubber pan gasket is more than enough to seal.
Re: leaky trans pan gasket [Re: goldmember] #1212506
04/10/12 08:46 AM
04/10/12 08:46 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Just went thru this on a non mopar. It was a rebuilt trans, so everything was clean and easier to see leaks. After going thru 3 gaskets I ended up doubling up the gasket and it’s now dry as a bone.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: leaky trans pan gasket [Re: Mike P] #1212507
04/10/12 11:10 AM
04/10/12 11:10 AM
Wi.
Wi.
That could be another option ! double gasket .
