leaky trans pan gasket
#1212488
04/09/12 12:44 AM
04/09/12 12:44 AM
Posts: 334 Wi.
65_gt_rag_402
Wi.
say what are you guys using for the trans pan gasket on a 727 ? buddys car leaked with the rubber gasket and we tried a cork with both side permatex high temp orange sealer and still leaked..
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!!
11.0's on pump gas .
Re: leaky trans pan gasket
[Re: 135sohc]
#1212492
04/09/12 01:27 AM
04/09/12 01:27 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I have been using one of the new reusable ones from Mopar
http://www.ebay.com/itm/Mopar-Lifetime-7...b5e&vxp=mtr
Ditto... Those things are awesome. Should be a stocking item at any dealership if you got one locally.
Likewise, but that said, I'm using mine with a cast aluminum pan with a thick flange. Dry as a bone on the outside, after a couple of on/off cycles.
[Re: Scamp408]
#1212495
04/09/12 05:55 PM
04/09/12 05:55 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
Thanks for all your responses on this issue you guys .. has anyone ever tried permatex ultra Black gasket sealer ? .. it's Suppose to work good too on gaskets .. but Heard it dries hard and very hard to scrape off later . heard the "right stuff" is good Too. Thanks !
[Re: Andrewh]
#1212496
04/09/12 06:22 PM
04/09/12 06:22 PM
Posts: 1,601 Hatfield,Pa.
bigD
Hatfield,Pa.
also be sure it is the pan gasket leaking.
I once thought that was what I was chasing down, went through 3 gaskets, 2 pans and thought it was still leaking, turned out to be the shaft seal.
others have seen it be the 0 ring at the dipstick tube.
don't waste a lot of time and money on the pan if you have not checked above it yet.
Same here(after 2 different pans & installing reusable gasket),it was the shaft seal,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
[Re: 65_gt_rag_402]
#1212497
04/09/12 06:28 PM
04/09/12 06:28 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Gravity is a funny thing , what may APPEAR to be the pan gasket leaking could be coming from a source above the pan ... and there are a few ... cooler line fittings , dipstick tube , shift shaft seals ...
Also if he has a chrome pan and has not removed the chrome from the gasket flange he is never going to get it to seal short of welding the pan to the trans.
[Re: JohnRR]
#1212498
04/09/12 07:40 PM
04/09/12 07:40 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
2X especially that pesky o-ring on the tube!
[Re: Andrewh]
#1212500
04/09/12 09:11 PM
04/09/12 09:11 PM
Posts: 1,322 Michigan
crlush
thought my gasket was leaking turned out it was the dipstick oring.
[Re: BDW]
#1212503
04/09/12 11:41 PM
04/09/12 11:41 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
no........ leaking right on the front edge of the trans plain as day and a drip on both the bolts that hold the manual shift cable to the pan with the 3/8" spacers..
[Re: 65_gt_rag_402]
#1212504
04/09/12 11:47 PM
04/09/12 11:47 PM
Posts: 334 Wi.
65_gt_rag_402
Wi.
buy the way............ it's not a deep pan OR Aluminum pan just the stock/standard depth 727 Pan.
[Re: 65_gt_rag_402]
#1212505
04/10/12 12:07 AM
04/10/12 12:07 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I'd guess you have a leak other than the pan gasket,as either the cork or rubber pan gasket is more than enough to seal.
[Re: goldmember]
#1212506
04/10/12 08:46 AM
04/10/12 08:46 AM
Posts: 1,514 AZ
Mike P
AZ
Just went thru this on a non mopar. It was a rebuilt trans, so everything was clean and easier to see leaks. After going thru 3 gaskets I ended up doubling up the gasket and it’s now dry as a bone.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears) under construction
