Starter help needed #1205320
03/28/12 06:53 PM
03/28/12 06:53 PM
southern in.
72sebring Offline OP
southern in.
I have 72 model 440 xh motor . When I built it I was told mini starter from Dakota v8 would work. Well it did for awhile! Dont have it off yet but belive gear is shot! What mini starter should use that will last? have headers so I think only a mini will work!
Re: Starter help needed [Re: 72sebring] #1205321
03/28/12 07:29 PM
03/28/12 07:29 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I used the mini from DB Electrical. No problems so far.
Scott
1969 Super Bee, 383/4 speed
Re: Starter help needed [Re: StukaJU87] #1205322
03/30/12 06:06 PM
03/30/12 06:06 PM
southern in.
southern in.
what is db elec.? number please This motor is actullay a 72 440 motor home block . if that matters?
Re: Starter help needed [Re: 72sebring] #1205323
03/30/12 06:40 PM
03/30/12 06:40 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
This is the 1st I've heard of a mini starter failing. They are much more reliable than the old style starter. Just goto a local parts store and get a new one using your old one as a core.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Starter help needed [Re: HemiRick] #1205324
03/30/12 06:48 PM
03/30/12 06:48 PM
Central TX
roe Offline
roe  Offline
Central TX
I got mine from Autozone with a lifetime warranty. No matter where I am, if it fails (this if the first i've heard of it actually happening) then I just pull it off and go to the nearest Autozone for a free one, FOR LIFE!!! I like that security and get it on all of my parts that I can. I have it on my waterpump, alternator, brake pads, distributor, etc...just to name a few. And so far I haven't had any quality issues from Autozone. Everything has held up fine.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Starter help needed [Re: roe] #1205325
03/30/12 06:51 PM
03/30/12 06:51 PM
Central TX
roe Offline
roe  Offline
Central TX
Oh, and the reason that I choose Autozone over Napa, Advance, etc...is because they track your warranty nationwide in their computer system thru your Ph#. The other stores you have to save your receipt for years in the event the it fails.
