Another 8 3/4 Detail Question #1199619
03/19/12 04:42 PM
03/19/12 04:42 PM
Jackson, Mississippi
CornDogsCharger Offline OP
I'm working on a '69 GTX with a 440, auto on the column, 8 3/4 with a sure grip 3.23. When cleaning it up I was able to find just a few black stripes under the chuck and you could see remnants of the white number on the side. The yellow stenciled numbers on the axle tube couldn't be seen. What are the correct numbers to go back on the rear end? And what do these numbers mean? Thanks for the help!!
Justin
"CornDog"
1966 Dodge Charger
1968 Plymouth Satellite (Un-Restored "Survivor")
1969 Dodge Charger (W.B. General Lee)
1969 Dodge Charger (Future DMCL Clone)
1969 Dodge Super Bee, 383 4spd
Re: Another 8 3/4 Detail Question [Re: CornDogsCharger] #1199620
03/19/12 05:08 PM
03/19/12 05:08 PM
Considering I never got a decent answer when I asked this question, I would like to know these things too!
Re: Another 8 3/4 Detail Question [Re: CornDogsCharger] #1199621
03/24/12 11:29 PM
03/24/12 11:29 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Justin
"CornDog"
If you are interested in what's stenciled and daubed on my '69 Barracuda A body 8 3/4 non-Sure Grip 3.23 built Hamtramck Nov '68 and how the markings relate to my build sheet (and part numbers), PM me with your email address so I can email back attachments.
Re: Another 8 3/4 Detail Question [Re: CornDogsCharger] #1199622
03/25/12 12:38 AM
03/25/12 12:38 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Justin
"CornDog"
Along with the three black stripes there should be a orange stripe to indicate it's a suregrip...
The numbers on the axle tube are the last three digits of the axle part number and the axle assembly date code....You need to have more info to pinpoint which axle it should have, drum or disc brakes? the number is shown on the broadcast sheet...
FWIW the white daub on the yoke indicates the pinion was torqued And typically there will be a assembly date on the pumpkin as well as the axle assembly date...
Re: Another 8 3/4 Detail Question [Re: 1_WILD_RT] #1199623
03/25/12 10:34 AM
03/25/12 10:34 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Heres my Duster rear end and pumpkin. Note the assy date is on both.
Re: Another 8 3/4 Detail Question [Re: NV69B7RR] #1199624
03/25/12 10:36 AM
03/25/12 10:36 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
3:91 sure grip Pumpkin
Re: Another 8 3/4 Detail Question [Re: 1_WILD_RT] #1199625
03/25/12 11:16 AM
03/25/12 11:16 AM
Great info! This GTX had manual brakes, 11x3 drums up front and 11x2.5 drums on the the rear. I wish I had more info to make it absolutely correct but this car's build sheet was lost long ago. Everything else we have (fender tag, window sticker).
When you said the #'s on the tube are the last 3 digits of the axle... do you mean the actual axle or the axle housing? I looked up the parts in the '69 parts catalog and the housing is 2852838 and the axle itself is 2852826. Which is correct? And usually, how far before the Scheduled Build Date should the rear axle assembly be dated? This GTX has a build date of 9-06-68. Thanks!!
Justin
"CornDog"
1966 Dodge Charger
Re: Another 8 3/4 Detail Question [Re: CornDogsCharger] #1199626
03/25/12 01:42 PM
03/25/12 01:42 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
My SPD is Oct 14, so 1 month before in my case.
Re: Another 8 3/4 Detail Question [Re: NV69B7RR] #1199627
03/25/12 02:18 PM
03/25/12 02:18 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
69 B body 3.23 SG 11" drums 7290 yoke 489 case is axle # 595
Per my fender tag my Challenger's SPD is A13 (Oct 13th) but the axle dates were pumpkin 10-27, assembly 10-28.... Obviously my car was a little late.. The engine was assembled 10-14 & the original door sticker shows the car was built in Oct 69 so at least for my car there was much lead time.....
Re: Another 8 3/4 Detail Question [Re: 1_WILD_RT] #1199628
03/25/12 05:02 PM
03/25/12 05:02 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Do the three black and one orange dabs also apply to a 68 version as well? 742 case, 3:23 sure grip.
Re: Another 8 3/4 Detail Question [Re: 68jim] #1199629
03/25/12 07:16 PM
03/25/12 07:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
742 is probably gonna mean a different color stripe... I know the 489 3.23 SG with the 7290 yoke in 69-70 was three black & an orange stripe... Wish I knew more...
