Another 8 3/4 Detail Question
#1199619
03/19/12 04:42 PM
03/19/12 04:42 PM
Posts: 412 Jackson, Mississippi
CornDogsCharger
I'm working on a '69 GTX with a 440, auto on the column, 8 3/4 with a sure grip 3.23. When cleaning it up I was able to find just a few black stripes under the chuck and you could see remnants of the white number on the side. The yellow stenciled numbers on the axle tube couldn't be seen. What are the correct numbers to go back on the rear end? And what do these numbers mean? Thanks for the help!!
Justin "CornDog"
1966 Dodge Charger 1968 Plymouth Satellite (Un-Restored "Survivor") 1969 Dodge Charger (W.B. General Lee) 1969 Dodge Charger (Future DMCL Clone) 1969 Dodge Super Bee, 383 4spd
Re: Another 8 3/4 Detail Question
[Re: CornDogsCharger]
#1199620
03/19/12 05:08 PM
03/19/12 05:08 PM
Considering I never got a decent answer when I asked this question, I would like to know these things too!
[Re: 1_WILD_RT]
#1199625
03/25/12 11:16 AM
03/25/12 11:16 AM
CornDogsCharger
Great info! This GTX had manual brakes, 11x3 drums up front and 11x2.5 drums on the the rear. I wish I had more info to make it absolutely correct but this car's build sheet was lost long ago. Everything else we have (fender tag, window sticker).
When you said the #'s on the tube are the last 3 digits of the axle... do you mean the actual axle or the axle housing? I looked up the parts in the '69 parts catalog and the housing is 2852838 and the axle itself is 2852826. Which is correct? And usually, how far before the Scheduled Build Date should the rear axle assembly be dated? This GTX has a build date of 9-06-68. Thanks!!
Justin "CornDog"
[Re: NV69B7RR]
#1199627
03/25/12 02:18 PM
03/25/12 02:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
69 B body 3.23 SG 11" drums 7290 yoke 489 case is axle # 595
Per my fender tag my Challenger's SPD is A13 (Oct 13th) but the axle dates were pumpkin 10-27, assembly 10-28.... Obviously my car was a little late.. The engine was assembled 10-14 & the original door sticker shows the car was built in Oct 69 so at least for my car there was much lead time.....
[Re: 1_WILD_RT]
#1199628
03/25/12 05:02 PM
03/25/12 05:02 PM
Posts: 1,029 Southeast Virginia
68jim
Southeast Virginia
Along with the three black stripes there should be a orange stripe to indicate it's a suregrip... The numbers on the axle tube are the last three digits of the axle part number and the axle assembly date code....You need to have more info to pinpoint which axle it should have, drum or disc brakes? the number is shown on the broadcast sheet... FWIW the white daub on the yoke indicates the pinion was torqued And typically there will be a assembly date on the pumpkin as well as the axle assembly date...
Do the three black and one orange dabs also apply to a 68 version as well? 742 case, 3:23 sure grip.
[Re: 68jim]
#1199629
03/25/12 07:16 PM
03/25/12 07:16 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
742 is probably gonna mean a different color stripe... I know the 489 3.23 SG with the 7290 yoke in 69-70 was three black & an orange stripe... Wish I knew more...
