RAM TRANS SHIFTING ISSUES #1191325
03/04/12 11:10 PM
03/04/12 11:10 PM
NY
MoparGary7272 Offline OP
NY
I replaced my blown 93 d150s trans(a518) with one from a 94... All I needed to replace was the input shaft. The trans shifts fine under regular driving but when you floor it to pass it's hangs up in gear and feels flat . Also going up hills it dogs it up and on the highway it struggles getting to 70... Fluid is correct atf +4 and level. can the TV cable be adjusted on the 318 magnums? Is this a solenoid failure? How can I get the truck to run accurately again?
Re: RAM TRANS SHIFTING ISSUES [Re: MoparGary7272] #1191326
03/04/12 11:14 PM
03/04/12 11:14 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I'm not sure what the problem is in your case, but I don't think your truck should have solenoids. I think they started in 96 when everyone went to OBDII. It should still be a straight juice (hydraulic) transmission. Why did you have to change the input shaft? Was your original tranny a non lockup? Is so, why didn't you just change the TC and all and make it a lock up?
I replaced the solenoids in my 96 tranny cause the symptom was because it would hang onto gears like it was in eternal kick down mode. I would have to take my foot all the way off the throttle to make it shift, sounds like you have a different problem
Re: RAM TRANS SHIFTING ISSUES [Re: WO23Coronet] #1191327
03/04/12 11:25 PM
03/04/12 11:25 PM
NY
NY
The TC was the one with the trans the shaft I changed was the one on the driveshaft cuz the splines were different.. I'm pretty sure there's a solenoid in it... Behind the trans filter... It does hang up at times. When I go to accelerate it should do so smoothly... And not rev high with out moving hardly faster
Re: RAM TRANS SHIFTING ISSUES [Re: MoparGary7272] #1191328
03/05/12 12:02 AM
03/05/12 12:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is the trans downshifting when you floor it and then does it upshift when picking up speed ? Ron
Re: RAM TRANS SHIFTING ISSUES [Re: MoparGary7272] #1191329
03/06/12 12:44 AM
03/06/12 12:44 AM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
I don't know if it is the cause of your problem, but the tv cable can be adjusted. There is a button where it latches onto the throttle body and it slides to adjust length. I don't know if they have different ratio levers on the transmissions like the older 727s, but it might be worth comparing the new one to your original also.
